Is GT3567R more worth getting than the T3/T67 H.O.
Which one is more worthed getting gt3567R or t3/t67 h.o. my power goal is 700+ whp i know that the gt3567r is ball bearing but is there a big differences in spool up time and powerband differences i know ball bearing cost a lot more but i want my money worthed.
Modified by integraboosted at 5:32 PM 12/26/2005
Re: Is GT3567R more worth getting than the T3/T67 H.O. (B00STFREAK)
The T3/T67 is a turbo for someone who is looking to get HI top end WHP .
If you are using this turbo for a road race car or you are using the car on the street get the GT35R , If you are using the car for 1/4 mile use and don`t mind the extra lag get the T3/T67 . If you search on the forum you will find many topics about the T3/T67 vs GT35R .
Re: Is GT3567R more worth getting than the T3/T67 H.O. (Marlon88)
The gt3567R is as capable as the t3/t67 HO. Geoff himself has stated this. The GT35R turbine wheel will handle the same amount of flow as the P trim turbine wheel in the t3/t67 HO.
Due to the gt3567R's ball bearing center section, and turbine wheel with a smaller moment of inertia, it will spool sooner then the t3/t67 HO as well.
Re: Is GT3567R more worth getting than the T3/T67 H.O. (Justin Olson)
Due to the gt3567R's ball bearing center section, and turbine wheel with a smaller moment of inertia, it will spool sooner then the t3/t67 HO as well.[/QUOTE]
I think he knows this...i believe he is asking if the faster spool up is worth the extra money.
Re: Is GT3567R more worth getting than the T3/T67 H.O. (integraboosted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraboosted »</TD></TR><TR><TD CLASS="quote">Which one would be better value a gt3567R or t3/t67 h.o. my power goal is 700+ whp i know that the gt3567r is ball bearing but is there a big difference in spool up time and power band difference. I know ball bearing turbos cost a lot more but i want my money's worth. </TD></TR></TABLE>
Re: Is GT3567R more worth getting than the T3/T67 H.O. (turbozxi)
i was always told the t3 exhaust turbine was to restrictive for much over 600hp...this true?
B18c1turboedEK
11-24-2004 10:56 PM
