boost problems!
Old Dec 20, 2005 | 06:12 PM
turbodcivic510's Avatar
Default boost problems!
yeah so i just finished putting together my HMT kit, its a ihi rhb5 turbo on a single cam zc, i had everything hooked up right and working fine. i got street tuned yesterday and today after gettign on it once or twice i noticed that my boost/vac gauge while at idle started like flickering pretty violently between 22 and 19 inch/vac but nothing else was wrong, it drove the same, i got home and checked my injectors and one of them we sorta leaking(dsm 450s , i think i ground down the rubber a little too much) but i pushed it in a little and it went away. but after driving awhile it came back , but settled down again. im stumped please help!
i need to know if its safe to drive my car to school tommorow...
thanx H-T
Old Dec 20, 2005 | 06:24 PM
VTcivicHB's Avatar
Default Re: boost problems! (g1_teg)
Hope school is downhill both ways! Jk I would say that you might have a vacum leak.
Old Dec 20, 2005 | 06:28 PM
Default Re: boost problems! (VTcivicHB)
ok, ill check that tommorow, any other suggestions?
Old Dec 20, 2005 | 06:49 PM
bump , i need help!
Old Dec 20, 2005 | 06:51 PM
98_4drCivic's Avatar
could be tuning. i had some idle problems with my sedan because i didnt play around with the fuel and ignition maps very much down below 2k rpms
Old Dec 20, 2005 | 07:03 PM
Default Re: (98_4drCivic)
ok kool, so i shoudl be ok driving normally and boosting 8lbs??
Old Dec 20, 2005 | 07:05 PM
Default Re: (g1_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g1_teg &raquo;</TD></TR><TR><TD CLASS="quote">ok kool, so i shoudl be ok driving normally and boosting 8lbs??</TD></TR></TABLE>
you should be alright. it isnt making any funny noises or anything is it?
Old Dec 20, 2005 | 07:21 PM
dc4rider's Avatar
i had the same problem on my friends car it turned out to be the pcv valve it was baiscly a vacuum leck /
Old Dec 20, 2005 | 07:45 PM
no it drives fine. no loping idle or anything, just starts flickering a whole lot...
Old Dec 20, 2005 | 08:03 PM
it the gauge mechanical or electronic? it could be the gauge.
Old Dec 20, 2005 | 08:43 PM
its mechanical, autometer phantom series... i just got it , i dont think thats it
Old Dec 20, 2005 | 09:35 PM
yeah, thats probably not what it is...just throwing the idea out there. crazier **** has happened.
edit: the reason i was asking is because if it was an electronic gauge, you could have a bad connection somewhere; or if its a mechanical gauge, i would check the vacuum/boost line where it goes onto the line that is hooked to your motor (usually the fpr vacuum line). its possible that for some reason the vibration from the motor at idle is causing a vacuum leak. this can happen if the line is not all the way in the little rubber piece. i hope that makes sense.
PNK SLP
Feb 21, 2011 09:56 PM
Ultra EK9
Feb 13, 2011 06:48 AM
rdssk8rcs1
Jun 9, 2006 04:35 AM
wickedxboi
Feb 28, 2003 10:21 AM
LOwrestling2001
Sep 18, 2002 11:22 PM
