compression test results ok?
Old Dec 25, 2005 | 10:52 AM
clemsonteg's Avatar
Default compression test results ok?
well being that today i dont have to do anything, I decided to tinker around on the teg. for back ground its an ls/vtec, gsr head eagle rods and je 9:1 pistons. I did a compression test today the motor was cold and i got 160psi + or - 3psi, is that good? i was told it wasnt really the numbers that mattered it was how close they were together, plus i figure being cold it made it a little lower. Just wanted some input on what it looked like to everyone else
Old Dec 25, 2005 | 10:58 AM
Jay_Sensing's Avatar
Well, since you did it cold, and I doubt you had the throttle wide open either, we really can't tell you anything man, it's good they are all close together but motors are all built differently and it should be done hot when everything is warm and expanded to where it should be. Then make sure they are all nice and close.
Some guys build motors with loose tolerances for FI so it really depends on your builder and such, just do the test right and see what you come up with.
Old Dec 25, 2005 | 12:02 PM
SpeedingHatch's Avatar
Default Re: (Jay_Sensing)
i get 160 +-5 in my 9.2:1 b16 cold and WOT, just as a reference
seems okay to me, but a leakdown test couldnt hurt
Old Dec 25, 2005 | 12:19 PM
tilt's Avatar
Default Re: compression test results ok? (clemsonteg)
you're fine.
Old Dec 25, 2005 | 12:36 PM
EK FLY's Avatar
Default Re: compression test results ok? (tilt)
MY GSR RESULTS WERE
180
180
183
178
same eagle and srp 9.1
97grnrs
Jul 22, 2006 07:52 PM
whoneedzvtec
Nov 27, 2005 08:52 AM
staticrex
Nov 15, 2004 01:30 PM
93H22ACX
Jul 15, 2004 02:33 AM
BoOsTiN Dc2
Mar 9, 2004 05:18 AM
