How does this regulator works?
Old Dec 24, 2005 | 05:00 AM
Turbocivic94's Avatar
Default How does this regulator works?
PAXTON FUEL PRESSURE REGULATOR 3 PORT BYPASS STYLE
Fuel Injector or Carb high volume bypass regulator
This is a new Paxton Products bypass (fuel return) style fuel pressure regulator. It has AN-10 inlet port and 2 AN-8 o-ring style outlet ports with a 1/8" npt port for gauge. It also has a vac-boost reference hose nipple for a turbo or supercharger to raise the pressure 1 to 1 ratio fuel pressure climb.This can be used on a car with big fuel requirments and big pumps. It is rated at 50lbs. inlet pressure max. and has a adjustment from 3-35 psi. Bonus!! This will also come with a high pressure fuel injector pressure spring (35-90 psi) so it can be used with fuel injector systems. This regulator is compatiable with gas or alcohol
Old Dec 24, 2005 | 05:14 AM
thermal's Avatar
So what's the question? It is just like any other aftermarket FPR to me.....
Old Dec 24, 2005 | 05:27 AM
Default Re: (thermal)
How does it work with carb and efi?
Old Dec 24, 2005 | 05:37 AM
EE_Chris's Avatar
Default Re: How does this regulator works? (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">This will also come with a high pressure fuel injector pressure spring (35-90 psi) so it can be used with fuel injector systems.</TD></TR></TABLE>
Old Dec 24, 2005 | 06:19 AM
Default Re: How does this regulator works? (EE_Chris)
Has anyone ever used this on our cars?
Old Dec 24, 2005 | 06:45 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
looks exactly like the pro series aeromotive regulator..
same?..
Old Dec 24, 2005 | 07:15 AM
tony1's Avatar
Default Re: How does this regulator works? (SYD)
It says it comes with both springs, that's all there is to it. Carbs run ALOT lower pressure than EFI systems...
Old Dec 24, 2005 | 08:24 AM
onlinehost's Avatar
Default Re: How does this regulator works? (tony1)
i have a paxton on my car and i love it
Old Dec 24, 2005 | 09:12 AM
I have one but I havent seen anyone use this type of regulator before on efi cars. I guess I'l be using it
danno33
Dec 27, 2006 02:16 PM
NuclearB18B
Sep 19, 2003 06:20 AM
iwouldHITit
Mar 8, 2003 09:52 PM
DR. ON POINT
Apr 4, 2002 02:07 PM
