Compression Ratio?
Old Dec 23, 2005 | 11:31 AM
HamiltonRex's Avatar
Default Compression Ratio?
Currently im at 9.8:1 According to http://www.c-speedracing.com
USDM B18C1 block, with USDM B18C1 Pistons, and a B16/ITR cylinder head. With stock 0.029" Headgasket. ~9.8:1
I plan to run a cometic HG, thickness 0.074". This will bring my compression down to about ~8.9:1 CR
This will be a stock block setup, tuned by me. Im sure this lower compression will help myself out with tuning this.. Correct? It will see fairly low boost 7-8psi daily.. and around 10-11psi at the track.
How does this setup sound?
Old Dec 29, 2005 | 07:16 PM
Default Re: Compression Ratio? (HamiltonRex)
Old Dec 29, 2005 | 08:55 PM
StylishDOHC's Avatar
I'm using the same .074 cometic in my otherwise stock B16 (aprrox 9.2:1)..... a lower compression ratio doesn't make it "easier" to tune really....but it gives you a little more room for error...i assume you have some sort of wideband 02 sensor?
Old Dec 30, 2005 | 10:54 AM
earl's Avatar
Default Re: Compression Ratio? (StylishDOHC)
On the negative side, using the thick head gasket takes away all the quench of that engine plus it throws your cam timing off about 3 degrees. You must correct that by using adjustable cam gears.
superturboprelude
Feb 24, 2015 09:56 PM
motormike40
Aug 17, 2007 04:38 PM
Chief Wenceslaw
Feb 7, 2006 05:59 PM
itralex
Apr 14, 2005 10:16 AM
typesguy
Nov 17, 2004 07:56 AM
