Which turbo for my setup..?
Old Dec 21, 2005 | 04:55 AM
crxnj's Avatar
Default Which turbo for my setup..?
Stock B16a
Log manifold with t3 flange
Plan on revving to 8,000rpm
Need power in the mid-high rpm range
HP goal is around 250hp-280hp ~ 10lbs of boost
Turboedit pm6 and 450cc dsm injectors
The turbos I'm looking at,,I've looked through the 6 pages of dynographs on evans-tuning website and can't decide..
-T3-super 60 ??a/r
-T3/t04e ??trim ??a/r
-T3/60-1 with .48 turbine
Any help is appreciated..
Old Dec 21, 2005 | 05:38 AM
GaRn's Avatar
Default Re: Which turbo for my setup..? (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Which turbo for my setup..?
Stock B16a
-T3-super 60 ??a/r
Any help is appreciated.. </TD></TR></TABLE>
go with a t3/t4.. .63 exhaust imo
or go with a holset :D
Old Dec 21, 2005 | 05:48 AM
The Weather Man's Avatar
t3/t4e 60 trim .63 a/r - good for 8k b16s.
Old Dec 21, 2005 | 05:56 AM
crxnj's Avatar
Default Re: (TheKINGPin)
What do you'll think about the t3/60-1 .48 turbine..I can get it really cheap but I dont want the wrong turbo for my application,,
Old Dec 21, 2005 | 05:57 AM
If you're only going for 280hp - it'll be too big.
I think the t3/t4e 60 trim .63 a/r is perfect for you - you'll actually be able to up the boost and won't max out the turbo until maybe ~420whp.
Old Dec 21, 2005 | 06:05 AM
crxnj's Avatar
OK thanks,I have another Question,,The place that sells them offers either a stage1,2,3 wheel..Which one would be better and what do the different stages of wheels affect..? Spool time,Air flow,? Are the wheels actually different in size?
Old Dec 21, 2005 | 06:39 AM
"The size of the wheel will have an effect on spool time (smaller=faster) along with turbine housing A/R however a bigger wheel will usually give a little more top end (providing it is matched properly with the compressor wheel). Much like having a huge turbo in general, thinking you need a large turbine wheel "just because" will most times hurt performance rather than help."
Smaller = faster spool up, however - you won't have the top end. So, if you plan to rev to 8k - get a stage 3. It'll be a tad bit slower spool up; however the turbo will still spool pretty quick. You can also get a ballbearing upgrade. It won't spool up as slow as an sc61, nor as fast as a t28 - but you get the picture. It'll be good.
Old Dec 21, 2005 | 07:14 AM
project dc2's Avatar
Default Re: (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">OK thanks,I have another Question,,The place that sells them offers either a stage1,2,3 wheel..Which one would be better and what do the different stages of wheels affect..? Spool time,Air flow,? Are the wheels actually different in size?</TD></TR></TABLE>
wheels are diffrent in size. drastically i'd stick with the stage 3 turbne wheel to spin that 60 trim wheel. itll give it leverage to spin it more effciciently. not many garretts come with a stage 1 or 2 wheel. unless its a rebuild
for 280WHP at 10 psi definatley 60 trim t3t4. stage 3 turbine .63 AR housing.
it might take a hair pas 10 psi to make it though.
Old Dec 21, 2005 | 08:18 AM
crxnj's Avatar
Default Re: (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
it might take a hair pas 10 psi to make it though. </TD></TR></TABLE>
The t3/t4 I'm looking at isn't a garrett..It's a turbonetics unit and it actually says offered in stage1,2,3 and 4 wheels in they're catalog..
I dont want to go past 10psi because I'm keeping the stock MAP sesor so you know..I think I should hit my goal because I'll also be playing with the cam gears and maybe be getting get some 96+ gsr cams if I can find some for cheap..
Old Dec 22, 2005 | 09:44 AM
yee SERIOUS's Avatar
t3/to4e .60 trim .63a/r (you can go .57trim too if you want)
t3/60-1 is too big
Old Dec 22, 2005 | 10:04 AM
KeyserSoze's Avatar
Default Re: Which turbo for my setup..? (GaRn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaRn &raquo;</TD></TR><TR><TD CLASS="quote">
or go with a holset :D</TD></TR></TABLE>
60 trim would be good or run a holset hx35 or hy35, the holsets really like high pr's.
Edit, just read your power goals, if 250-280 is all you want then just get either of the holsets or a 50 trim.
Yareka
May 5, 2008 06:44 PM
turbosol_16
Dec 27, 2006 06:41 AM
LSR-Abuser
Oct 21, 2005 12:55 AM
The Crow
Jan 11, 2004 09:10 PM
Optiks.
Dec 5, 2003 06:07 PM
