What intercooler do I have?
Old Dec 19, 2005 | 04:36 PM
huntarrr's Avatar
Default What intercooler do I have?
Came with the drag kit... i was told it was a Spearco by the seller. Later, I was told that the core looks nothing like a Spearco.. Do any of you know?
Old Dec 19, 2005 | 04:43 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: What intercooler do I have? (vsm98civic)
drag3 intercooler, uses a spearco core
Old Dec 19, 2005 | 06:24 PM
huntarrr's Avatar
Default Re: What intercooler do I have? (wantboost)
so does this look like a spearco core or no?
Old Dec 19, 2005 | 06:26 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">drag3 intercooler, uses a spearco core</TD></TR></TABLE>
Old Dec 19, 2005 | 06:37 PM
turbotime's Avatar
yup, i got the same one- its pretty good for up to 300ish whp
Old Dec 20, 2005 | 08:15 AM
huntarrr's Avatar
Default Re: (turbotime)
so drag doesn't use any other cores?
thanks.
Old Dec 20, 2005 | 08:19 AM
tony1's Avatar
Default Re: (vsm98civic)
Yeah, it's the drag ic, i'm not sure that it's a spearco core though. Those things suck, sorry. They're a little better than no ic. Spend a couple bucks and get a garrett/precision core...
Old Dec 20, 2005 | 08:20 AM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm98civic &raquo;</TD></TR><TR><TD CLASS="quote">so drag doesn't use any other cores?
thanks.</TD></TR></TABLE>
I believe it was answered before... twice.
Old Dec 21, 2005 | 03:26 PM
huntarrr's Avatar
Default Re: (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">I believe it was answered before... twice.</TD></TR></TABLE>
Apologies.. I didn't know if there were different 'stages' of Drag kits, or if all the fmic's were the same from kit to kit. Say, if the integra drag fmic was the same as the civic drag fmic.
But.. I'm not too worried if it sucks. I spent $215 shipped for everything in the picture, so as long as it does its job (200whp on a d-series), then I'm fine with it.
Old Dec 21, 2005 | 05:50 PM
nsxmatt's Avatar
The Drag IC is good to 400whp. It's a good IC for the money and it will fit under the bumper support and mine never got heat soaked.
Old Dec 21, 2005 | 05:54 PM
tony1's Avatar
I don't think that ic is very efficient at that power level. Why do you say it is?
Old Dec 21, 2005 | 05:57 PM
nsxmatt's Avatar
Default Re: (tony1)
At 400whp it's not, but for the power he is making (less than 300whp) it's a good setup and should do him well.
Old Dec 21, 2005 | 06:00 PM
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">The Drag IC is good to 400whp. It's a good IC for the money and it will fit under the bumper support and mine never got heat soaked.</TD></TR></TABLE>
Old Dec 22, 2005 | 02:55 AM
nsxmatt's Avatar
What's not hard to understand? The IC will flow and is rated up to 400whp, at the 400whp level it's not the most efficent intercooler but will work. He is not planning but half that power so the intercooler will work fine for him without having to spend $600 on a marked up overkill IC like you suggested.
Old Dec 22, 2005 | 05:08 AM
crxnj's Avatar
What's wrong with that intercooler ? Looks pretty thin but is still efficient as long as you don't go over the limit..
Old Dec 22, 2005 | 06:11 AM
tony1's Avatar
So what makes it "rated" to 400hp? If it's inefficient at less than 400hp, where do you get 400hp from? You can mek 500hp on it, why not say it's good for 500hp? Because it's so inefficient at those power levels that it's really hurting performance. And i'd hardly say a $400 garrett intercooler is a marked up overkill ic...
Old Dec 22, 2005 | 06:41 AM
igo4bmx's Avatar
i gotta mention this IC works well with 99-00 fogs
Old Dec 22, 2005 | 07:17 AM
nsxmatt's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">So what makes it "rated" to 400hp? If it's inefficient at less than 400hp, where do you get 400hp from? You can mek 500hp on it, why not say it's good for 500hp? Because it's so inefficient at those power levels that it's really hurting performance. And i'd hardly say a $400 garrett intercooler is a marked up overkill ic... </TD></TR></TABLE>
I really don't know what makes it rated, just the fact they can run a power level without heatsoaking the IC or running crazy intake temps. I did alot of research when running my old Drag setup and found many people running the drag setup at the 400whp level and working fine. I can't say another IC would make more power, i'm sure nobody could without testing them back to back. I'm sure a $400 garrett IC would be a little more efficient, but for double the cost of his IC and piping kit and for the power he is making it's not worth it.
Old Dec 22, 2005 | 07:21 AM
93supercoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">. I'm sure a $400 garrett IC would be a little more efficient, but for double the cost of his IC and piping kit and for the power he is making it's not worth it.</TD></TR></TABLE>
I agree
Old Dec 22, 2005 | 07:22 AM
tony1's Avatar
There's another thing to look at, that's ofter overlooked. Pressure drop, a small ic like that has ALOT of pressure drop at big hp levels, that's the more limiting factor than efficiency. It's fine for 250-300hp, but past that it really starts becomming a burden.
Old Dec 22, 2005 | 07:29 AM
nsxmatt's Avatar
Default Re: (tony1)
I thought it was the other way around? Why does it have pressure drop?
Old Dec 22, 2005 | 07:38 AM
tony1's Avatar
That's the common misconception. Think about it. You're trying to cram a ton of air through a small hole, what happens? The hole is a restriction and will cause more pressure on the inlet side than the outlet side. A big ic is not as much of a restriction, so there is less pressure drop. IC efficiency is only a small part of the equation with intercoolers. The cross sectional area of the core is very important. That drag ic is short and very thin...
Old Dec 22, 2005 | 09:27 AM
yee SERIOUS's Avatar
what if the IC is short and thick? does that make up for some length? my ic is 26inches long, but is 3.5inches thick. would that be ok for up to 300hp?
i guess for this guy, he can't beat the price. he can always resell the ic and get a new one. just keep the pipes. but for his goals, it's fine.
Old Dec 22, 2005 | 09:28 AM
tony1's Avatar
Default Re: (undercoverdc2)
Thickness and height make way more difference than length...
chrisgottigsr
Sep 24, 2005 02:44 PM
19sec beast
Aug 14, 2005 04:17 PM
98cwitr
Jul 21, 2004 03:36 PM
Spooled1.6L
Feb 15, 2004 02:38 AM
99B16Si
Nov 19, 2003 09:51 PM
