arp headstuds
Old Dec 21, 2005 | 11:32 AM
seanclark's Avatar
Default arp headstuds
i recently added arp headstuds to my d16z6 but one of the studs sits higher than the rest, is this normal ?
Old Dec 21, 2005 | 11:41 AM
platinum00's Avatar
Default Re: arp headstuds (seanclark)
which one is it.
i think the top right corner does sit higher if you hand tighten them.
pre-torque them to 15lbs and they should all be the same.
platinum.
Old Dec 21, 2005 | 12:03 PM
seanclark's Avatar
yeh was one of the corner ones, and i did hand tighten them, its ok then if thats meant to happen, when i actually torqued them all up as per arp guides they seemed to sit level
Old Dec 21, 2005 | 01:52 PM
zeroice's Avatar
if i remember correctly on the y8 the top left one sits higher... so i would imagine the z6 would have 1 sit higher as well... you can look at the head and tell it should be a lil taller where that one is..... hope that helps
Old Dec 21, 2005 | 02:50 PM
platinum00's Avatar
Default Re: arp headstuds (zeroice)
could be the top left i dont remember
but either way it's pretty common.
dont worry about it
just get everything to spec w/multilube
platinum
Old Dec 21, 2005 | 03:17 PM
EnzoSpeed's Avatar
Default Re: arp headstuds (platinum00)
Why must this dead horse be beaten so unmercilessly every other week?
1. On a z6, the top left corner stud sticks up higher when properly installed (hand tight).
2. On a y8, the bottom left corner stud sits lower when properly installed (hand tight).
Whether you have a z6 or a y8, the studs should NEVER be flush with each other. If they are, you must have ignored ARP's directions about HAND-TIGHTENING them.
It's not brain surgery - look at the bolt surfaces on the head and you'll understand. Or, just drop the head down onto the studs and watch as the high/low stud magically becomes the perfect length.
socialburn0035
Jul 24, 2008 03:14 PM
yz125rider21
Oct 3, 2006 12:27 PM
AgentJam
Sep 10, 2004 05:15 PM
stingray2772
Jul 18, 2003 09:55 PM
senpai
Feb 6, 2003 06:16 PM
