sohc boost question
Old Dec 19, 2005 | 09:07 PM
mugencivic94's Avatar
Default sohc boost question
want to rebuild me d16z6 so i can use more boost a friend of mine suggested boring the block .40 instead of stock bore but wont that raise your compression plan on gettin forged internals block gaurd bearing kit and head bolts and possibly other things but would it be better to bore it out if so what compression pistons should i go with. or is it best to stick with stock bore thanks
Old Dec 19, 2005 | 09:21 PM
crxnj's Avatar
Default Re: sohc boost question (mugencivic94)
Its better to overbore the cylinders so you know you have a true circle..I would overbore 0.5 though ,, not 0.4 .
Old Dec 20, 2005 | 05:03 AM
USDM 4G VTEC's Avatar
Default Re: sohc boost question (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Its better to overbore the cylinders so you know you have a true circle..I would overbore 0.5 though ,, not 0.4 .</TD></TR></TABLE>
hes probably talking 0.040 not 0.4
0.040 is 0.5mm wich is the biggest u can get for aftermarket pistons like JE and still have plenty of sleeve
Old Dec 20, 2005 | 05:47 AM
so would this raise the compression, and if i stick to overboring it what compression should i get the 8:1 or 9:1 thanks for the info
Old Dec 20, 2005 | 07:42 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugencivic94 &raquo;</TD></TR><TR><TD CLASS="quote">so would this raise the compression, and if i stick to overboring it what compression should i get the 8:1 or 9:1 thanks for the info</TD></TR></TABLE>
9:1
Old Dec 20, 2005 | 07:44 AM
BiG Chris's Avatar
it wouldnt really raise the comp ratio but when you order up some pistons talk to the tech guys and they will set you straight on what you need to get.
Old Dec 20, 2005 | 07:45 AM
nickromeo's Avatar
.040'' is closer to 1mm no?
Old Dec 20, 2005 | 07:49 AM
JayDiem_k20_Dc5's Avatar
From: University of Massachusetts, Amherst, Ma, US of A
Default Re: sohc boost question (nickromeo)
if you plan on boosting I would use 8:1. and as for boring I wouldn't bore too much, you need as much sleeve as possible when boosting, sure a blockguard will help with flexing a lot and is an alternative to using iron sleeves but if you boost way to much say good-bye to your block. Sleeves will only make your block virtually bulletproof
Old Dec 20, 2005 | 08:58 AM
tgreaves's Avatar
Default Re: sohc boost question (JayDiemB16aCivic)
Why would you go with 8:1, thats just crazy.. Stick to 9:1-9.5:1..
Old Dec 20, 2005 | 09:06 AM
platinum00's Avatar
8.1 is just to low for street applications i think.
stick with 9.1
platinum.
Old Dec 20, 2005 | 09:07 AM
RyanEJ8's Avatar
Default Re: sohc boost question (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">8.1 is just to low for street applications i think.
stick with 9.1
platinum.</TD></TR></TABLE>
Old Dec 20, 2005 | 09:30 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: sohc boost question (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
0.040 is 0.5mm wich is the biggest u can get for aftermarket pistons like JE and still have plenty of sleeve</TD></TR></TABLE>
Incorrect.
0.020" is 0.5mm. You bored your block 0.040", which is 1mm over, or 76mm.
greddy2smoke
Mar 1, 2007 03:25 PM
berts95ej
Sep 5, 2006 07:55 PM
igo4bmx
May 18, 2004 05:24 PM
NXAccordTO4B
Jul 19, 2003 08:27 PM
CRVRX
May 27, 2003 07:08 PM
