using crower stage 3 on a turbo setup
Old Dec 24, 2005 | 04:23 AM
Ak_ef9's Avatar
Default using crower stage 3 on a turbo setup
Is it safe to use crower stage 3 non-vtec cams on a turbo setup? I was going to go all motor but I might be going turbo because of the power I want.
Old Dec 24, 2005 | 06:45 AM
JDogg's Avatar
Default Re: using crower stage 3 on a turbo setup (Ak_ef9)
no
Old Dec 24, 2005 | 07:01 AM
mrx's Avatar
mrx
Default Re: using crower stage 3 on a turbo setup (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">no</TD></TR></TABLE>
why shouldn't it be safe?
Old Dec 24, 2005 | 07:20 AM
DRAGLS's Avatar
Default Re: using crower stage 3 on a turbo setup (mrx)
yes you can use them, I am currently running their stage III 404s' on my turbo setup.
Old Dec 24, 2005 | 07:21 AM
JDogg's Avatar
it will blow all the fuel out of the exhaust, the wideband will read rich, but the engine will actually be running like dog ***.
Old Dec 24, 2005 | 07:27 AM
h22 civic's Avatar
not a good idea
Old Dec 24, 2005 | 07:32 AM
DRAGLS's Avatar
Default Re: using crower stage 3 on a turbo setup (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">not a good idea</TD></TR></TABLE>
Have YOU used them?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">it will blow all the fuel out of the exhaust, the wideband will read rich, but the engine will actually be running like dog ***.</TD></TR></TABLE>
Have YOU used them?
Old Dec 24, 2005 | 07:51 AM
mrx's Avatar
mrx
is this a problem of the crower stage3 cam's itself? or is it a general Problem?
if it is general, NA guys may have the same problem (maybe not so worse because they don't have boost)
maybe some cam gears will help.
Old Dec 24, 2005 | 08:58 AM
The Tea-father's Avatar
you can use any cams, but the question is why? is there a benefit of using the stage 3 cam over a Gsr or type R? we made 700hp last year with a crower 401-T.
Old Dec 24, 2005 | 11:10 AM
JDogg's Avatar
Default Re: using crower stage 3 on a turbo setup (The Tea-father)
i have, it dosnt work. you will make more power and have a better running car with stock cams.
Old Dec 24, 2005 | 11:32 AM
Ak_ef9's Avatar
thanks everyone might just stick with stock
Old Dec 24, 2005 | 12:35 PM
pdiggitydogg's Avatar
this is all opposed to the info by many others thats states otherwise
do a search and you'll see what I mean...
403's (even 404) with gears, some tuning, and you'll make more power than any turbo or stock cams (apparently)
Old Dec 24, 2005 | 01:38 PM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx &raquo;</TD></TR><TR><TD CLASS="quote">
maybe some cam gears will help.</TD></TR></TABLE>
this is a problem with any NA cam generally... for hte most part anythign stage 2 or bigger has too much overlap. you can fix this somewhat with cam gears, but then you get the valve open and closing all wacky..
The Tea-father: he has an LS...
the crower turbo cams work well, if you want an upgrade thats what i would recomend.
turbo boost
Mar 3, 2008 07:34 PM
mickey1
19
Nov 18, 2007 07:09 AM
Fezzie
19
Oct 3, 2006 06:50 PM
M.A.R.C.
Apr 12, 2006 02:15 PM
