Most boost PSI from Airresearch T3
Old Dec 19, 2005 | 04:21 PM
MikeD718's Avatar
Default Most boost PSI from Airresearch T3
Since i wreked my turbo EJ8 I have my motor (d16y8) pulled and am going to build for more boost in my 96 hatch. I wondering how much boost psi I could get from an Airresearch T3 .42/.48 A/R. It was pushing 9psi daily fine and was wondering how much more i could get out of it without switching to something bigger. Im not looking for huge numbers just wanted to know what it was capable of producing. Any help would be appreciated.
-Mike
Old Dec 20, 2005 | 03:59 AM
MikeD718's Avatar
Default Re: Most boost PSI from Airresearch T3 (MikeD718)
bump
Old Dec 20, 2005 | 05:32 AM
Bailhatch's Avatar
If you have a big one you can make high 200s if you have a small one you can make low 200s.
Old Dec 20, 2005 | 05:36 AM
tgreaves's Avatar
I was running a Airesearch T3 .42/.48 on a d16y7 with 13psi and made 200whp..
Old Dec 20, 2005 | 05:45 AM
HiProfile's Avatar
Default Re: Most boost PSI from Airresearch T3 (tgreaves)
Just from looking at the compressor map http://majesticturbo.com/20268.html, I'd have to say after a 2.5 pressure ratio (21psi). After that, it's dropping below 70% effeciency. In the real world, I'd be guessing after 18psi it'll be pushing mostly hot air.
Old Dec 20, 2005 | 05:52 AM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">I was running a Airesearch T3 .42/.48 on a d16y7 with 13psi and made 200whp..</TD></TR></TABLE>
what size?
Old Dec 20, 2005 | 06:31 AM
tgreaves's Avatar
Default Re: Most boost PSI from Airresearch T3 (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">
what size?</TD></TR></TABLE>
What do you mean.. It was a T3 .48/.42, 45 trim..
It was off of a Mercedes diseal from the junkyard..
Old Dec 20, 2005 | 07:58 AM
MikeD718's Avatar
so if i built my motor and ran in the neighborhood of 15 psi the turbo should perform fine?
Modified by MikeD718 at 5:06 PM 12/20/2005
Old Dec 20, 2005 | 08:57 AM
tgreaves's Avatar
Well get it tuned, while on the dyno you can find out where the power of the turbo falls off.. Mine was on a bone stock y7 motor btw..
Old Dec 20, 2005 | 10:20 AM
EK k kay's Avatar
A buddy of mine put down 196whp / 172wtq at 8psi with one of those T3 .42/.48 on his stock z6. It stops making power after 6k though.
Old Dec 20, 2005 | 01:07 PM
MikeD718's Avatar
Default Re: Most boost PSI from Airresearch T3 (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">A buddy of mine put down 196whp / 172wtq at 8psi with one of those T3 .42/.48 on his stock z6. It stops making power after 6k though.</TD></TR></TABLE>
do you think it stops making power due to the wastegate opening?
Old Dec 20, 2005 | 01:09 PM
tgreaves's Avatar
It would stop making power because you have ran out of the turbos power range..
Old Dec 21, 2005 | 12:31 PM
EF8 D-UNIT's Avatar
I would get rid of it annd go to at least a laarger T3, as with the Y8 your power is gonna fall on its face after 5-6k and if you have a turbo setup and your gonna pay for tuning, why dont you spend the extra money to have something that is small but kicks a little more ***? Wouldnt it be worth it?
Just my opinion…
-Rob
Old Dec 21, 2005 | 12:48 PM
MikeD718's Avatar
Default Re: Most boost PSI from Airresearch T3 (EF8 D-UNIT)
What size T3 would you recomend?
Old Dec 21, 2005 | 12:50 PM
AbitAvenger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeD718 &raquo;</TD></TR><TR><TD CLASS="quote">What size T3 would you recomend?</TD></TR></TABLE>
14b from a dsm
Old Dec 21, 2005 | 12:51 PM
EK k kay's Avatar
do you think it stops making power due to the wastegate opening?</TD></TR></TABLE>
Because it's a small turbo that dies out in the top end.
Old Dec 21, 2005 | 07:16 PM
MikeD718's Avatar
ive been doing some reading and i think im going to go with the T3 super 60. it seems like it can support my HP goals and will not break my bank.
RedTT
Mar 27, 2007 01:52 PM
Turbo_y8
Feb 2, 2006 09:20 PM
GsRHatchy1320
Nov 20, 2004 06:11 PM
Del_Slowest
Oct 27, 2004 12:08 PM
BOOSTEDCIVICD16
Jan 29, 2004 04:40 PM
