What do you think
i wanna know what i should expect this motor to make
it has been on the dyno before but i had a couple of things to fix
dizzy
bottle neck in the exhaust
charge pipes - were poppin off/ rubber elbow
well i fixed all that here is my setup
erl sleeved motor 84mm - cp pistons 9.7:1 - crower rods - gsr crank - acl bearings - type R oil/water pump - fulidamper balencer - arp studs
headgames PnP head - fully manley valve train - gsr cams - skunk2 gears - arp studs - brand new OEM td44u dizzy - ngk plugs/wires - crane transparent blue cap/rotor
all oem gaskets btw
drag gen 3 turbo kit - t3/t04e 57trim turbo - tial 38mm WG - HPC coated mani/custom closed loop DP/turbo housin - upgraded SS oil feed/return lines - GE oil sandwhich adapter - new alumn. charge pipes bead rolled ..t-bolt clamps - greddy type-RS BOV - NXexpress N-ter cooler kit -
AEBS intake mani--port matched to a JG 65mm TB
aem fuel rail and hi-flow fuel filter - upgraded fuel lines with SS lines
RC 750cc injectors and walbro intank 255lph HP fuel pump
pwr fullsize raditor - spal slimline fan kit - samco blue hoses (upper/lower)
ge vacum mani - ge oil sandwhich adapter -
full-race custom catch can -
all assembly by full-race
Hondata s200 with all options on a p72 ecu - all tuning done by Joe @ Locash
gm 3-bar MAP sensor
greddy profec B boost controller
plx m-300 wide band o2 controller
i wanna know how much power to expect of runnin pump gas...shitty 91 octane...i beat my motors up
so what do you guys think
dizzy
all oem gaskets btw
gm 3-bar MAP sensor
Well with the T04E 57 trims I've seen them pushing as much as 400-450HP, but that was really pushing the turbo. You can probably see 300-350WHP if you push the turbo a little, but I dont know if you'd want to max the turbo out to get it to the 400+HP mark.
Zerolift-Robert
Jul 11, 2011 06:35 AM
