Psi/Boost question and the relationship with hp
Old Dec 23, 2005 | 04:58 AM
k-series's Avatar
Default Psi/Boost question and the relationship with hp
I'm trying to understand something and want to get the facts straight.
If I have a 2.0L motor with a T3/T4 pushing 6psi and another identical motor with a GT25 pushing 6psi will the hp output of the motor be the same?
Meaning: Is 6psi of boost equal to the same hp from any turbo?
Steve
Old Dec 23, 2005 | 05:39 AM
Joseph Davis's Avatar
Default Re: Psi/Boost question and the relationship with hp (k-series)
No, it would be different. All other things being equal except the turbo:
Two different compressors operate at two different efficiencies.
Two different turbines have two different amounts of restriction to the exhaust flow out of the engine. They are nalso rated in terms of efficiency, but not as commonly.
The turbine runs the compressor, so flow across the turbine effects the flow output from the compressor.
All these things impact power output to a greater or lesser extent.
Old Dec 23, 2005 | 05:58 AM
Muckman's Avatar
Moderator in Chief
https://honda-tech.com/zerothread?id=1469539
Old Dec 23, 2005 | 06:08 AM
B00STFREAKS's Avatar
Default Re: Psi/Boost question and the relationship with hp (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1469539</TD></TR></TABLE>
Beat me to it.
Old Dec 23, 2005 | 06:32 AM
AbitAvenger's Avatar
good info
Old Dec 23, 2005 | 06:47 AM
k-series's Avatar
Default Re: (AbitAvenger)
That's what I thought and someone was arguing differently.
Thanks for the replies guys!
Steve
CRX_Phantom1
Jan 26, 2006 04:37 PM
mugentype-r
Nov 2, 2005 01:42 PM
mrbsponge
May 4, 2005 05:05 PM
GsRHatchy1320
Nov 20, 2004 06:11 PM
Mikey3000
Nov 10, 2004 01:16 PM
