car not building boost.... Help????
Old Dec 19, 2005 | 11:17 AM
dominikano24's Avatar
Default car not building boost.... Help????
I have a problem that im not building boost..... i know it possibly could be a vacumm prob but ive gone through all my vacumm lines over and over and still 0-psi of boost when i drive........ i have a 92 integra da, i have the GE vacumm manifold and have the following pluged into it... BOV- FPR-boost gauge,profec-s boost controler,3bar map sensor, i have those 5 things running off GE vacumm manifold.... im running a tial 38mm and i have the side of it vacummed to the turbo.... can anyone tell me anything that i need to check cause ive done everything that i could think of....... when im at idle and i rev the motor i hear the bov blowing so i dont think the turbo is bad but why am i not boosting..... help!!! thanks in advance...
Old Dec 19, 2005 | 11:47 AM
yee SERIOUS's Avatar
boost leak in the pipes?
Old Dec 19, 2005 | 05:18 PM
blackeg's Avatar
Default Re: (undercoverdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 &raquo;</TD></TR><TR><TD CLASS="quote">boost leak in the pipes?</TD></TR></TABLE>
thats my first thought. check all your intake piping to make sure they are connected and not leaking
Old Dec 19, 2005 | 05:49 PM
bubs's Avatar
I'd have to agree about leaky or disconnected charge pipes. Did it ever make any boost? Is this a new turbo setup?
The only other thing I can think of if this is a new setup is to make sure you have the spring in the wastegate and the sealing ring (can't remember what that thing is called ) that goes between the wastegate and wastegate flange. Good luck
Old Dec 19, 2005 | 06:03 PM
Right on the $$$$$$ thank you.... i hate it when it something stupid like that......... 1 pipe was completely loose...... i'll fix it and hope that fixes my prob.......
Old Dec 19, 2005 | 06:06 PM
andysila's Avatar
always gotta double check
Let us know how it is.
Old Dec 21, 2005 | 09:12 AM
andysila's Avatar
fix it?
Ultra EK9
Feb 13, 2011 06:48 AM
1sic3dr
Aug 11, 2007 03:28 PM
crew08 (girlygirlracer)
Oct 13, 2005 07:58 PM
lopster
Sep 4, 2004 01:01 PM
HRC51
Sep 3, 2003 11:16 PM
