bone stock b18c1 oil recommendations
I've been using Castrol GTX 5w30 since i bought my car.
2001 Integra GSR, bone stock block, 330whp/246wtq on high boost.
I have not run into anyt problems with the Castrol, I'm just open to some advice. I'm a firm believer in "if it ain't broke don't fix it", but would just some clarification why a lot of turbo honda owners tend to jump to 10w30. I do not experience any oil loss, compression tests yield great results....I just wan't to extend the motor's life any way I can.
All input is appreciated
Re: bone stock b18c1 oil recommendations (yehiknowrite)
i use 5w40 during winter, 15w50 or 20w50 during summer and a mix of 5w40 and 20w50 in between. synthetic only and never energy concerving oils.. check bobistheoilguy.com . 10w30 doesn't offer more protection and in some brands thinner than 5w30.
well...i'm going to have to go back out what I said last night.
went out to the car this morning, checked the oil before going to work, and was a little low. seems there was some burning over the past weekend, I was driving the car pretty hard. now...would it be beneficial to go with Castrol GTX 10w30? Should I stay with the 5w30?
I'm in NJ....spring is just around the corner...shouldn't see any actual cold temperatures for awhile.
i have a sc61 on my b18c1 13psi and i used to run gtx 5w30 but i noticed oil pressure dropping pretty low when i get her nice and hot after about 3 - 4 runs (10 psi idle, 65 wot) and it seemed like it was burning up the oil in the turbo.
i went up to 10w30 and it was the same. tried mobil1 15w50 and the oil pressure was above 15psi at idle and 70+ wot. it also didnt turn black as a struck match after 20 miles i went to gtx 10w40 and that seems to keep me happy.
IntegraType-R
10-15-2007 02:28 PM
