Did a leak compression test....are these god numbers?
Did a leak compression test....are these good numbers?
225,225,225,225
8%,8%,9%,10%
It's an 01 GSR with t3t4 turbo boostin 10lbs with hondata.
The reason I did the test is that I am having some real bad smoking issues. I have been messing with an oil catchcan and I think it might be the culpret. The way I have it hooked up is black box to catchcan and valve cover to catchcan venting to atmosphere, no PCV valve is installed.It is either that or valve seals. Any suggestions?
Thanks in advanced,
Matt
8%,8%,9%,10%
Thanks in advanced,
Matt
EF8_SiR
07-20-2003 10:24 PM
RATEDR
06-06-2002 03:24 PM
