Quick fuel pump question...
Old Mar 22, 2006 | 06:36 PM
boostedcivic24's Avatar
Default Quick fuel pump question...
i just got done instaling my turbo...t3/t04e .57 trim .63 ar...i have 550cc injectors right now i have a stock fuel pump in my 99 si and it wont start cranks and everything..could the stock fuel pump not be giving enough fuel and thats why its not starting???if so what size fuel pump would i need
Old Mar 22, 2006 | 06:41 PM
Turbo-charged's Avatar
Default Re: Quick fuel pump question... (boostedcivic24)
you need a walbro 255 fuel pump atleast, HOWEVER the stock fuel pump would not cause your car to not start.
have you checked to see if it is getting fuel? is it getting spark?
Old Mar 22, 2006 | 06:55 PM
Jin.'s Avatar
what ems are you running? is it even setup for 550's?
Old Mar 22, 2006 | 07:33 PM
teddy_dc2's Avatar
ran same set up with no injectors untuned, ran fine except the car would take a **** after the beating, the walbro 255 installed ran a lot smoother.
Old Mar 22, 2006 | 07:41 PM
Default Re: (teddy_dc2)
well..i have obd2b to obd1 with hondata s200 and a p28 ecu that has a base map for 550cc injectors..however the p28 ecu isnt installed i still have the stock ecu in
Old Mar 22, 2006 | 07:51 PM
Default Re: (boostedcivic24)
so you have your stock ecu trying to controll 550cc injectors?
you just answered your own question
Old Mar 22, 2006 | 07:56 PM
Default Re: (Turbo-charged)
thanks...i didnt know...so it should run when i plug in the p28 ecu
Old Mar 22, 2006 | 07:58 PM
if the basemap is good, then yes.
if it doesnt start then, put the stock injectors back in it with the stock ecu JUST FOR START UP.
before you do anything.....check to make sure the car is getting spark, and make sure it is getting fuel. any CEL's?
Old Mar 22, 2006 | 08:32 PM
one code....IAT circuit high output
boostedjd
Engine Management and Tuning
Jul 3, 2013 06:05 PM
Tylerjdmgsr
Jul 20, 2011 04:22 PM
lowtegsr
Jan 12, 2008 05:57 PM
si0385.
Jan 14, 2006 11:51 AM
Vp Special K
Jul 18, 2005 11:52 AM
