surging!!!!!!! DISTRESS
Old Mar 22, 2006 | 06:52 AM
jacky599r's Avatar
Default surging!!!!!!! DISTRESS
ok well. im boosted. running a turbo from mitsubishi 4g93t and vr4 injectors. went to tune my emanage but damn it was a bad day. idle at warm up is like real low. 500s thereabt. it has minor jerks at idle. like those with high cams kinda feel. the tuner says there something wrong with my turbo. it starts to spool at 2.5k rpm there abouts and suddenly onset off boost up to 19psi at 4krpm. what could have happened? he says the boost cant be control. that aside. when moving off from low gears. the car jerks as well. somewhat like im feeding fuel intermittently. This last through ard 3krpm for all the gears. The weird thing is... my car stalls WHENEVER I WANNA DOWNSHIFT FROM 5TH GEAR....clutch in... the car stalls! DISTRESS!
Old Mar 22, 2006 | 07:06 AM
Importordomestic's Avatar
Default Re: surging!!!!!!! DISTRESS (jacky599r)
im not trying to be a jack *** or anything, but the whole problem with the jerking is the Fuel management. get rid of the Greddy emanage and either put a stand alone ecu in the car ex: Motec, AEM, SDS, etc / or haver your stock ecu chiped and tuned with crome, hondata, etc.
as for the boost spiking, i probably would contribue that (assuming that you are still using the stock internal wastegate) to a bent wastegate actuator rod. or a worn out diaphram in the wastegate in itself.
Old Mar 22, 2006 | 08:23 AM
jacky599r's Avatar
im running them on th e7th gens. hmm,regarding the boost spike.. will it solve the problem if i change the turbo? or is it possible that i get ride of the wastegate actuator... or even the internal wastegate
Kid-jdm-teggy
Mar 21, 2014 07:14 AM
avotegra
May 8, 2007 04:14 AM
GWInquisitor14
Jun 5, 2005 12:06 PM
krazn
Sep 16, 2004 10:12 AM
BlueSi2k
Dec 23, 2003 07:31 AM
