oil restrictor
Old Mar 22, 2006 | 09:23 PM
bizzlekip's Avatar
Default oil restrictor
I have a 2000 civic si running a ssautocrap kit... yeah i know. Since the turbo has been installed the car has been burning a decent amount of oil. I just did a compression test on it showed an even 200 on all 4. I am aware the problem could be within the head, but am thinking it might be the fact it is lacking an oil restricted and catch can. Any ideas or personal experiances would be helpful
Old Mar 22, 2006 | 11:32 PM
Dunc's Avatar
BCICAN
Default Re: oil restrictor (bizzlekip)
What size oil feed line are you using for your turbo? Also, do you know what kind of pressure your turbo is seeing at WOT?
-4AN line - get a restrictor
-3AN line - you could get a restrictor here too if you're turbo seals are going out, or if it's the cause of burning the oil due to high pressures.
Old Mar 22, 2006 | 11:34 PM
Blackack26's Avatar
Inspect the charge pipes and turbo housings for oil, check the exhaust ports in the head to see if the valve seals are leaking.
Old Mar 23, 2006 | 05:06 AM
nonvtecD's Avatar
I use a restrictor and catch can, both a good idea.
boostedSI90hatch
May 16, 2007 12:26 AM
Blkteg97
Nov 16, 2004 08:04 AM
AlphaKennyWun
Oct 4, 2004 12:47 PM
filetofit
Sep 5, 2002 09:26 PM
Ri5e
Jun 20, 2002 10:41 AM
