Which Blox cams are best for my setup??
Old Mar 20, 2006 | 11:30 PM
G-Phi's Avatar
Default Which Blox cams are best for my setup??
I'm looking for the best Blox cams for me setup. Thanks for your input.
My setup: 83mm turboed b18c1 motor, valves, springs and retainers have be upgraded.
Modified by G-Phi at 1:22 AM 3/22/2006
Old Mar 21, 2006 | 02:41 AM
DaveF's Avatar
Default Re: Which Blox cams are best for my setup?? (G-Phi)
none?
sk2stg2's or stg1's would be killer
Old Mar 22, 2006 | 12:09 AM
G-Phi's Avatar
Default Best for my setup??
Between the three which would be the best for my turbo GSR setup?? Which would give me more horsepower and torque??....
Blox? (If Blox, which ones?? Turbo cams?? Type A cams?? etc.)
Skunk2? (If Skunk2.....which stage?? 1, 2 etc.)
ITR cams?
I'm looking for people who have actually used these cams and/or dyno results also. I'd like to see the difference so that I can compare.
Thanks!
Modified by G-Phi at 9:17 AM 3/22/2006
Old Mar 22, 2006 | 08:21 AM
G-Phi's Avatar
Default Re: Best for my setup?? (G-Phi)
I'm not looking to get cams from people who are just trying to make a sale. Performance is important to me. Performance wise, which cams are most definately the best??
Thanks!
Old Mar 22, 2006 | 08:24 AM
G-Phi's Avatar
Default DturboCivic
DturboCivic..............Which cams are you using in your setup??
Old Mar 22, 2006 | 11:41 AM
sp00led's Avatar
Default Re: DturboCivic (G-Phi)
Search around and you will find that the best turbo cams for our bseries are ITR/CTR. Full race just came out with a new set of turbo cams which appear to out perform the CTR's. Might want to check that post out.
Old Mar 23, 2006 | 11:14 PM
G-Phi's Avatar
Default Re: DturboCivic (sp00led)
Thanks! I'll check it out.
Old Mar 24, 2006 | 12:46 AM
TurboJesse
Guest
Posts: n/a
Im running blox b's
Old Mar 24, 2006 | 08:30 AM
G-Phi's Avatar
Default (TurboJesse)
What's your setup and how much torque and horsepower did you gain?
SilverEF88
Dec 18, 2010 10:44 PM
97blacklude
Sep 24, 2008 09:02 PM
jsteezy1290
23
May 15, 2004 06:38 PM
IntegraNut
Oct 25, 2002 09:43 PM
