Help on install... where do these go?
Old Mar 19, 2006 | 02:04 PM
civicdust's Avatar
Default Help on install... where do these go?
This is my setup. a homemade turbo. turbo out of a talon, gaskets, adapter.. u know..
Where does this thing go? do i need it?
Look at this buddy. Where does this dirty guy go? god i suck @ guessing.
Look at this guy. is this for the oil? i dont know....came off a talon i tell you.
This is the "Test-on" longblock. a d15z1. This turbo is going on my hatch, with a d15b8. I want to abuse the ******, while i build my d16z6.
Anyways, i know how to install the turbo, but i have a question. What side of the turbo goes where? does the silver side go towards the tranny, or towards the timing belt?
What else do i need to buy? i already ordered the pipes, the oil pan and the bov. What else am i going to need? i already searched. i found some good links, but none mentioned where the top hoses go to.
Old Mar 19, 2006 | 02:08 PM
stockredej1's Avatar
Default Re: Help on install... where do these go? (Joon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joon &raquo;</TD></TR><TR><TD CLASS="quote">
Ok pic #1 Oil Return, puts oil back into the oil pan #2 & #3 are coolant feeds and return, really dont need these
My sugestion is research a bit more before putting the kit on. Check out homemadeturbo.com. there are alot of dsm setups there.
Good luck and have fun
Old Mar 19, 2006 | 05:29 PM
civicdust's Avatar
Default Re: Help on install... where do these go? (stockredej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockredej1 &raquo;</TD></TR><TR><TD CLASS="quote">
Good luck and have fun </TD></TR></TABLE>
Thanks for the input. I am researching. I just had those questions. Also, how does the turbo go? silver side to th tranny, or to the timing belt?
Old Mar 19, 2006 | 05:46 PM
1Quikgsr's Avatar
Thanks for the input. I am researching. I just had those questions. Also, how does the turbo go? silver side to th tranny, or to the timing belt?</TD></TR></TABLE>
you need to clock the turbo, depends how you want it either way but you need the dp made to go with what directions you want
Old Mar 19, 2006 | 06:07 PM
Tactic$'s Avatar
I just researched some of the threads Joon has created.
It turns out, he really is this dumb.
Someone help this guy out!!!!
honda86si
Sep 17, 2005 01:08 PM
ososlow24
Apr 8, 2005 08:40 AM
dornon13
Aug 17, 2004 08:38 AM
MachAF
Mar 5, 2003 05:32 AM
badassb18c
Jan 3, 2003 03:43 PM
