AVCR VS AEM with GM boost solenoid
Old Mar 20, 2006 | 07:04 AM
underpressure02's Avatar
Default AVCR VS AEM with GM boost solenoid
I have been running the AVCR for the last 2.5 years and running AEM for my EMS. I am redoing my entire setup and looking to make some sick power. Some people have suggested that I ditch the AVCR and just run the GM boost solenoid with my AEM to help with traction issues. People that are running the GM BS with AEM how do you like it and would you recommend that over the AVCR.
Old Mar 20, 2006 | 07:58 AM
mstolars's Avatar
Default Re: AVCR VS AEM with GM boost solenoid (underpressure02)
The GM solenoid works very well if you can figure out all the settings for it. Also, AEM is coming out with a solenoid of their own that is just like the Apexi solenoid that supposedly is more accurate, but I have never used that one because is it quite pricey compared to the GM one. Give it a shot, if you get it set up properly, you'll never want to go back.
Old Mar 20, 2006 | 11:56 AM
BodyKits NW's Avatar
Default Re: AVCR VS AEM with GM boost solenoid (mstolars)
Well from what people have told me the AVCR works great if you know how to dial it in properly. I heard it can be pretty complex. I personally don't have any experience with it.
I run the GM solenoid with the AEM EMS. I don't see any reason why anyone would not want to use it. It works flawlessly and it seems to be a lot easier to setup than the AVCR. Why not use it? You basically got everything that a AVCR can do and it only cost like 40 bux to get it going. I just like the fact that I can do basically anything I want with it. The only feature I have yet to use is the low/hi boost switch setup. The speed dependant boost is more of my thing. I gotta say, I wouldn't know jack **** about the AEM EMS if it wasn't for Jason "JDOGG"
Old Mar 20, 2006 | 01:43 PM
Jared's Avatar
ditch the avcr and sell it. you'll end up with cash in pocket and a better controller
Old Mar 20, 2006 | 01:52 PM
luterole's Avatar
Default Re: (Jared)
With AEM EMS you need to change the settings with the laptop and all that "stuff". AVCR you can adjust any time with no tools. There is some advantage to that. Other than that, i doubt one functions significantly better than the other.
Old Mar 20, 2006 | 01:54 PM
cluelessmale's Avatar
Default Re: (luterole)
go simple , here is the link for part numbers
http://forum.aempower.com/bbs/viewtopic.php?t=3047
Old Mar 20, 2006 | 02:11 PM
DaveF's Avatar
Default Re: (cluelessmale)
use the apex solenoid with the aem
and for people that dont have the apex solenoid. use the perrin solenoid. google it.
Old Mar 20, 2006 | 02:14 PM
mrbsponge's Avatar
i have "heard" and i dont know first hand, that the AEM was only good and accurate up to 25psi, is this correct?
Old Mar 20, 2006 | 02:19 PM
DaveF's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">i have "heard" and i dont know first hand, that the AEM was only good and accurate up to 25psi, is this correct?</TD></TR></TABLE>
how could be possible when they have them working with a 5 bar map?
Old Mar 20, 2006 | 03:30 PM
b18ccivics's Avatar
Default Re: (Dturbocivic)
i run a air valve that looks the same as aem (i havent seen aem's valve in person just pics on the internet) and have not had any problems. i can get a few cheap if anybody is interestd. it has 1/8 npt ports. pm me
Old Mar 20, 2006 | 03:55 PM
DaveF's Avatar
Default Re: (b18ccivics)
sent
Old Mar 20, 2006 | 04:54 PM
D-tuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">sent</TD></TR></TABLE>
X2
Old Mar 20, 2006 | 06:57 PM
FastEK9's Avatar
Default Re: (D-tuned)
Anyone know the Hz on the apexi or greddy silinoids?
Old Mar 21, 2006 | 02:22 AM
DaveF's Avatar
Default Re: (FastEK9)
this is what i found on the apex-i solenoid
Apexi Boost Controller Solenoids For all APEX Boost Controllers. This will also work with the AEM ECU. If you use this with the AEM ECU, set the frequency to 30Hz in the AEM. Run the Red wire to ignition power. Run the black wire to pin E9-60 (for 93-98 Supra) on the AEM. On the boost control solenoid itself, if you're using an external wastegate, run the COM side to the TOP port on the wastegate. Run the NC port to the Side port on the wastegate and T off this line and run it into the IC pipe right after the turbo.
Old Mar 28, 2006 | 12:19 PM
morgan@synapse motorsport's Avatar
so if u run aem ems, with a gm boost solenoid, the aem can act as a speed activated boost controller?
Old Mar 28, 2006 | 05:37 PM
DaveF's Avatar
Default Re: (hybrdthry911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrdthry911 &raquo;</TD></TR><TR><TD CLASS="quote">so if u run aem ems, with a gm boost solenoid, the aem can act as a speed activated boost controller?</TD></TR></TABLE>
yes
25 dollar boost solenoids
Old Mar 28, 2006 | 05:45 PM
b18ccivics's Avatar
yes and you can still have a high/low boost switch
so, on the street you can set a vss based ramp up to a set pressure on low boost, then at the track you can have the same ramp but go up to a higher level on high boost, it is great.
Old Apr 30, 2006 | 12:07 PM
b18ccivics's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ccivics &raquo;</TD></TR><TR><TD CLASS="quote">i run a air valve that looks the same as aem (i havent seen aem's valve in person just pics on the internet) and have not had any problems. i can get a few cheap if anybody is interestd. it has 1/8 npt ports. pm me</TD></TR></TABLE>
i have a few if anybody is interested
Old Apr 30, 2006 | 12:22 PM
alpha's Avatar
Not true. I ran 31lbs with AEM EMS on a GT35R powered GSX.
Old Apr 30, 2006 | 05:00 PM
11SEC CIV's Avatar
Default Re: (0x64)
can u have more then high/low w/ aem. Currently I have 12 psi below 65mph/18psi over, Is it possible to have a 3rd setting??
Old May 1, 2006 | 03:34 PM
b18ccivics's Avatar
Default Re: (12SEC CIV)
you can ramp up as steep or as flat as you like. ex 15=5psi 20=7 25=9 30=11 35=13 40=15 etc.
civic4lif
May 2, 2009 10:12 AM
h22_crx
Feb 5, 2007 08:09 PM
StrokedPSI
Aug 2, 2004 12:19 AM
1fstevo
Dec 10, 2002 05:31 AM
