Injector and clips
Old Mar 22, 2006 | 05:32 AM
elpiar's Avatar
Default Injector and clips
Hi, I'm planning to get RC440 high impedance (saturated) and was told it takes OBD1 clips, can I use clips from DSM450 blue tops? are they the same?
Old Mar 22, 2006 | 05:40 AM
VTteg's Avatar
Default Re: Injector and clips (elpiar)
Doesnt matter, clips are just clips. As long as you get the leads soldered to the correct wires, you will be all set.
Old Mar 22, 2006 | 06:37 AM
elpiar's Avatar
Default Re: Injector and clips (VTteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTteg &raquo;</TD></TR><TR><TD CLASS="quote">Doesnt matter, clips are just clips. As long as you get the leads soldered to the correct wires, you will be all set. </TD></TR></TABLE>
I don't think so. there are different clips with different injectors or OBD1 and OBD2 clips.
Otherwise, I would have used my original clips for my DSM.
Anyone else?
Old Mar 22, 2006 | 06:47 AM
notoriousB's Avatar
blue top clips will fit, you MIGHT have to just notch them slightly to fit the RCs, but I'm not 100% sure if that's even necessary.
Old Mar 22, 2006 | 07:27 AM
VTteg's Avatar
Default Re: Injector and clips (notoriousB)
What I mean was that all the clips have the same function. And as long as you have clips that fit/make the clips fit the injectors, you should be ok.
Old Mar 22, 2006 | 07:59 AM
HiProfile's Avatar
OBD1 clips are fairly universal. The few major injector brands use the same basic clip for topfeed injectors. The only few differences are just tabs inside of the injector's 'clip port', external clip size (possible fuel rail fitment issues), and retenetion design.
If you have access, I'd say dodge caravan v6 clips (obd1 would be mid 90's). I've heard they have the easiest removal, as opposed to the annoying honda design. I also just put the clips I got from autozone (8pk online), and I really like them. Need to be slightly cut for stock honda injectors, but fit perfect on RC's and DSM's. You push&hold the metal 'loop', and then they just slip off. PLUS they're black, unmolested, new... and cheap Not the best if you hate crimping though.
jewpont
Jul 11, 2009 01:24 PM
nix94delsol
Apr 7, 2009 02:29 AM
97turboteg
Apr 25, 2006 03:56 PM
RACEPAK
Jul 19, 2005 09:51 AM
Panoply
Jul 18, 2005 09:36 AM
