Question: Ever done Before? Carbon Fiber Charge Pipe
hey well i was just wondering if anyone has ever doen this before, why or why not a good idea. JW if the jays/password jdm intake chamber would be good for a turbo'd car charge pipe.. See diagram of how id like to use it. I thought the chamber is the best vortex of air, so how come no1 has ever mixed N/A engineering with FI? ALSO cf is agood disapator of heat.... I could hook up the bov near the intercooler, or lower on the charge piping....
reasons why i think n/a isnt mixed...the vortex you speak of helps air w/ no pressure scavenge and roll into the manifold...whereas in a boosted senario you want as less turbulent areas as possible...hence the round pipe...this huge tube you speak off would cause the flow to slow down...and at the last place you want it to...get very unstable...hence why i doubt youve ever seen it this way...but what do i know...its just my thoughs on it all
Re: (drumking15)
awsome thanksf or the info
just a question i had
therefore for air flow in turbo systems.. uw ant the MOST direct straight paths?
Re: (DarkBB4)
correct...and the bends you want to be as smooth as possible...and when you clamps your charge piping together...you want the piping to actaully almost touch...so there isnt a change in the id of the pipe around the coupler area...because it creates turbulence...same thing goes for welding slag...you dont want it creatin interference in the piping
Re: (mrbsponge)
that piping looks to me to be laid over an aluminum piece, you can sgtill see the welds, and by the throttle body placement looks to also have an air research manifold. please correct me if im wrong
Re: (PhoenixTurboJesse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhoenixTurboJesse »</TD></TR><TR><TD CLASS="quote">That piping is overlayed...ive talked to the owner before about it
Functionable? Or bling factor?
Re: (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller »</TD></TR><TR><TD CLASS="quote">that piping looks to me to be laid over an aluminum piece, you can sgtill see the welds, and by the throttle body placement looks to also have an air research manifold. please correct me if im wrong</TD></TR></TABLE>
yes it is overlaid, but it still looks pretty good for being done at home, and i cannot confirm nor deny the intake manifold
i should have known you would know whos car it is
Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">you mean something like this??
sorry had to edit the pic, the owner will remain anonymous at his request
That looks like that jkobd guys car Jason or something.
It runs an a.i.r. manifold and full race turbo manifold, don't remember if it was topmount or not.
Re: (sihatch19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sihatch19 »</TD></TR><TR><TD CLASS="quote">
nope, same color, but it actually is an intercooler protype blower set up this is the reason for the anonymity
i HAS questions ?
Re: (mrbsponge)
I believe Morgan at Synapse Motorsport and Jesse at Phoenix Turbo have messed around with carbon fiber charge piping before. If I remember correctly though, they said it was too much of a hassle.
Re: (daveG)
its arguable that cf piping would help...now i know you were talking about the na intake being used for part of the charge piping but that has already been covered, but that being said other than being liightweight carbon fiber would transfer heat really well...the question is will it transfer heat into your intake charge or out of the charge into the engine bay. tough question for me
Guest
Posts: n/a
Re: (daveG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG »</TD></TR><TR><TD CLASS="quote">I believe Morgan at Synapse Motorsport and Jesse at Phoenix Turbo have messed around with carbon fiber charge piping before. If I remember correctly though, they said it was too much of a hassle.</TD></TR></TABLE>
It was 100% just for cosmetics...im not gonna argue any performance standpoint
Re: Question: Ever done Before? Carbon Fiber Charge Pipe (DarkBB4)
I know of someone that had actually made his piping out of Carbon Fiber and that's it... He never completely finished the product and boosted it but he did make the piping... It was never tested or anything either... But it looked pretty cool....
Re: Question: Ever done Before? Carbon Fiber Charge Pipe (Split Image Prez)
Jesse and I made that pipe a longtime ago, I am currently working on a cf piping kit, there will be dyno testing with it, so we can see how functional it really is. Look for the pipes this summer
Re: Question: Ever done Before? Carbon Fiber Charge Pipe (Synapse Motorsport)
I think the only thing it would add is more boost lag.....it works in an NA setup because it is bigger piping going into a smaller chamber when this happens it causes a drop in pressure resulting in an increase in velocity of the air so the air is traveling faster into the ports, but on a turbocharged vehicle I would think that the manifold pressure is going to be fairly constant and all that tube would be is just more space to pressurize....I really don't know anything about this but that is just my 2 cents
Guest
Posts: n/a
Re: Question: Ever done Before? Carbon Fiber Charge Pipe (turbozxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi »</TD></TR><TR><TD CLASS="quote">Mpire or whatever his name was has carbon piping.</TD></TR></TABLE>
That was me..a few names ago
TurboJesse
01-04-2004 05:31 PM
