oil lines???????
Old Mar 19, 2006 | 06:28 PM
zccr-xsi's Avatar
Default oil lines???????
i have a teo4h trubo and i need to know what kind of oil line kit should i oder?are they the same size as the 14bs?and how big is the drain flange?
Old Mar 19, 2006 | 07:27 PM
ProjectDarkBlack's Avatar
Default Re: oil lines??????? (vteckillenzc)
Most people will say a Stealthmode kit, you can get it for your turbo specifically, and it is just under a hundred.
Old Mar 19, 2006 | 08:10 PM
stealthmode62's Avatar
Default Re: oil lines??????? (ProjectDarkBlack)
Thanks Dark black. Our kit is $85 shipped, but if you look in my signature I'm doing another free giveaway this month.
On your drain flange, you can measure it from the center of one mounting bolt hole, to the center of the other. 38mm is your typical 14B, 44mm= T25, and 50.8mm= T3.
Just to be sure on the inlet thread size I'd take the turbo to your local hardware/home depot and to the hardware section and test fit some different sized threads into the turbo to verify the exact thread size. More than likely you'll end up with a M12x1.25, but it's always good to check before ordering.
(I wish everyone did)
Speedra500
Sep 5, 2008 05:59 PM
malubawla
Jan 25, 2007 04:05 PM
catchthis92hatch
Sep 8, 2006 10:52 PM
catchthis92hatch
Sep 8, 2006 03:52 AM
Beau Gotti
Apr 1, 2005 06:44 AM
