Can I use this piston now???
Old Mar 18, 2006 | 09:37 PM
mahatma's Avatar
Default Can I use this piston now???
I was measuring my clearances today. Was tapping the Eagle rod caps back & forth to get them separated for the rods cause they were pretty well stuck on there. It was going fine, then my friend decided to get all He-Man on one of them....ripped the rod cap off but slammed the piston into the engine stand.
Is this usable?? If not, is it possible to buy a single replacement SRP anywhere??
Old Mar 18, 2006 | 09:44 PM
ExospeedAMcrx's Avatar
Default Re: Can I use this piston now??? (mahatma)
thats still usable. Im assuming since you are using SRP, that you're not planning on big power/high boost anyways. You might get hot spots in those areas, but you're on low boost anyways and most likely not going to experience any trouble.
Smoothen it out a bit so theyre not as rough, but it should be cool.
abnaasefmb's Avatar
just clean it up with some fine sandpaper, only need to take the rough edges off dont get crazy.
Old Mar 18, 2006 | 10:38 PM
mahatma's Avatar
Default Re: Can I use this piston now??? (exospeedAMcrx)
OK that's good news. I didn't know if they had some coating that I shouldn't sand off or something.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">Im assuming since you are using SRP, that you're not planning on big power/high boost anyways.</TD></TR></TABLE>
Why? Shitty piston? They're 9.2:1 CR
I'm shooting for at least 250whp daily on an LS....
Old Mar 19, 2006 | 12:51 AM
no not shitty. theyre just not made for high hp applications. SRP are the budget pistons. I wouldnt use them if planning big power. but you are good for 250hp.
Old Mar 19, 2006 | 05:13 AM
Mugencrxsir1's Avatar
Default Re: (exospeedAMcrx)
I'm not sure what people are talking about, I've seen SRP pistons on 300-450hp hondas, but I have'nt seen any on the 500+hp honda. So what's considered High horsepower these days, and what hp are SRP good too?
Old Mar 19, 2006 | 05:41 AM
USDM 4G VTEC's Avatar
theres a dremel tool that is a bit made out of "rubber" and is used to finely sand down metal
use that on there to get the rough-ness out
that can be used, no biggy
hot spots happen on sharp edges
smooth it out and you will be golden
Old Mar 19, 2006 | 10:59 AM
Default Re: (Mugencrxsir1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure what people are talking about, I've seen SRP pistons on 300-450hp hondas, but I have'nt seen any on the 500+hp honda. So what's considered High horsepower these days, and what hp are SRP good too? </TD></TR></TABLE>
alot of engine builders will say that SRPs are kept to HP levels under 250hp. im sure it can handle more, thats not impossible. but once you are going for more power, they choose JE, Arias, Wiseco, CPs.
High HP in my opinion is 350+
MantisX
Nov 18, 2011 03:54 AM
GarageAlchemist
14
Jun 18, 2006 06:16 PM
sexycheto88
Nov 7, 2005 07:13 PM
D21X
May 31, 2003 05:21 PM
