fmu good or bad
Old Mar 21, 2006 | 07:22 AM
motorhead_guy's Avatar
Default fmu good or bad
Is a fmu good to run on a stock ls motor with 7 psi
Old Mar 21, 2006 | 07:37 AM
bag's Avatar
bag
Default Re: fmu good or bad (motorhead_guy)
I use them only if bosting less ~6psi or less and wit inline high flow fuel pmp.. wut is ratio on the fum u want to use?
Old Mar 21, 2006 | 07:50 AM
I Have an STD's Avatar
wrenchin'
Default Re: fmu good or bad (BRIJPURT13B)
no. fmus are bad
Old Mar 21, 2006 | 07:54 AM
Muckman's Avatar
Moderator in Chief
Its fine if you only boost a little bit like you are. They get a bad rep because nobody ever tunes with with a wideband so they have no idea where the fuels at. If you dont have any kind of ignition management at least retard the distributor.
Old Mar 21, 2006 | 08:46 AM
VTteg's Avatar
Default Re: fmu good or bad (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Its fine if you only boost a little bit like you are. They get a bad rep because nobody ever tunes with with a wideband so they have no idea where the fuels at. If you dont have any kind of ignition management at least retard the distributor.</TD></TR></TABLE>
Isnt that because an FMU isnt tunable?
Old Mar 21, 2006 | 09:24 AM
Schister66's Avatar
Man U FTW
spend a little more and get something that doesn't suck!
Old Mar 21, 2006 | 09:28 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (Schister66)
FMU's are great.
for 0 psi
Old Mar 21, 2006 | 09:40 AM
Muckman's Avatar
Moderator in Chief
Default Re: fmu good or bad (VTteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTteg &raquo;</TD></TR><TR><TD CLASS="quote">Isnt that because an FMU isnt tunable? </TD></TR></TABLE>
Sorry I was refering to adjustable ones. However if its not you could swap discs out.
Old Mar 21, 2006 | 09:58 AM
mrbigg9032's Avatar
Old Mar 21, 2006 | 10:30 AM
VTteg's Avatar
Default Re: fmu good or bad (mrbigg9032)
I dont think you are going to find much help on here regarding FMU's.
Old Mar 21, 2006 | 10:35 AM
rmcdaniels's Avatar
My FMU worked well for when I no longer wanted my ring lands attached to my pistons.
joshfish79
Mar 6, 2007 09:59 PM
astig* DC2
Jun 21, 2005 09:59 PM
f1 vtec
Aug 28, 2004 07:50 PM
kovert
Aug 17, 2004 09:58 AM
adhana2
Jun 12, 2003 05:03 PM
