Header stud kit
Old Mar 21, 2006 | 08:51 AM
StolenTeg's Avatar
Default Header stud kit
Does anyone know who make header stud kit for a b18, i know arp make some but i couldnt find them.
Old Mar 21, 2006 | 09:05 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Header stud kit (StolenTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know who make header stud kit for a b18, i know arp make some but i couldnt find them.</TD></TR></TABLE>
Your saying to put studs in the head?
Old Mar 21, 2006 | 09:11 AM
StolenTeg's Avatar
Default Re: Header stud kit (HybridHatch88)
Header, i want to run all stud and nut instead of bolt. OEM coem with like 4 stud and 5 bolt, i want to run all stud and bolt
BTW, What are the size of the header stud or bolt?
Old Mar 21, 2006 | 10:22 AM
RobbieG35's Avatar
12 Years Strong
I bought my studs for my Si at Honda.
Old Mar 21, 2006 | 10:33 AM
rmcdaniels's Avatar
I bought the my exhaust studs at Ace Hardware, then got some stainless bolts for them and haven't had any problems with it.
Old Mar 21, 2006 | 10:51 AM
StolenTeg's Avatar
Default Re: Header stud kit (rmcdaniels)
rmcdaniels, what size of the stud did you buy?
Old Mar 21, 2006 | 10:55 AM
rmcdaniels's Avatar
I just took one of the bolts out and matched it up to the right stud.
Old Mar 21, 2006 | 11:06 AM
StolenTeg's Avatar
How did you tighten down the stud properly?
Old Mar 21, 2006 | 11:11 AM
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">How did you tighten down the stud properly?</TD></TR></TABLE>
I put two nuts on it, tightened them against each other to lock them down, very carefully ran a tap through the holes to get them cleaned out, then put some high-temp loc-tite on it and tightened it using the outer nut of the two. I've had 23 PSI turbo setups on it, ran N/A for a bit, and now have a supercharger and haven't had to mess with the exhaust fasteners. Just make sure you have a good flex section in there, back when I used to have a straight pipe all the way back I used to have problems with the exhaust nuts coming loose.
Old Mar 23, 2006 | 05:00 AM
LoseRPunKx182's Avatar
the studs are 8x1.25mm thread, does anyone know how long they should be?
Prudz_lude
Mar 29, 2007 01:18 PM
vtekthis
Oct 1, 2006 12:50 PM
92integraVTECgsr
Feb 15, 2006 10:57 AM
People_Mover
Jun 3, 2004 07:44 PM
VSM EXtasy
Jul 9, 2003 07:06 PM
