walbro 255 lph
Old Mar 20, 2006 | 12:18 PM
tegrunner's Avatar
Default walbro 255 lph
someone told me that this fuel pump is pushing my system too much and that i need a aftermarket fuel pressure regulator.
is this true,
i am running a tdo5 18g greddy turbo kit on my 00 ls with emanage
thanks for all of your guys help
Old Mar 20, 2006 | 12:28 PM
92LsTegra's Avatar
no this is not tru, i am currently running the 255 lph with no fpr, it would just make the tunner's life a lil easier.
Old Mar 20, 2006 | 12:36 PM
2point2's Avatar
Default Re: walbro 255 lph (tegrunner)
The walbro flows WAY more gas than stock.. From my searching I've come to the conclusion that you DO need an aftermarket FPR for the walbro if you want your fuel pressure to be at the OEM setting.
I'm half way though a walbro install right now can't stand the smell of gas and also need an installation kit.
Old Mar 20, 2006 | 12:38 PM
AbitAvenger's Avatar
Default Re: walbro 255 lph (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">The walbro flows WAY more gas than stock.. From my searching I've come to the conclusion that you DO need an aftermarket FPR for the walbro if you want your fuel pressure to be at the OEM setting.
I'm half way though a walbro install right now can't stand the smell of gas. </TD></TR></TABLE>I hated installing my walbro. What kinda car you putting it in?
Old Mar 20, 2006 | 12:41 PM
EK k kay's Avatar
Default Re: walbro 255 lph (AbitAvenger)
It depends on which Walbro 255lph. There's the High pressure version and the regular version.
Old Mar 20, 2006 | 12:42 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbitAvenger &raquo;</TD></TR><TR><TD CLASS="quote">I hated installing my walbro. What kinda car you putting it in?</TD></TR></TABLE>
CRX..
I went though hell the last time i changed the tank so it was much easier this time with new hose clamps, rubber lines etc.. also drained the tank though the return line this time.. very clean way to drain most of the tank.
Old Mar 20, 2006 | 01:10 PM
mike1114's Avatar
sometimes the pump can cause a higher than desired fuel pressure and force more fuel out of the injector than it is supposed to spray, this is cause the return line cannot send enough fuel back to the tank.
There is a how to on the old one.com (endyn site) on how to drill a 0.035 hole in the fuel return so more fuel can go back to the tank.
Old Mar 20, 2006 | 11:31 PM
2point2's Avatar
Default Re: walbro 255 lph (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">There is a how to on the old one.com (endyn site) on how to drill a 0.035 hole in the fuel return so more fuel can go back to the tank.</TD></TR></TABLE>
http://www.theoldone.com/articles/regulator/
Old Mar 21, 2006 | 02:48 AM
non-VTEC's Avatar
i had to do this mod also.......it makes the engine idle soooooooo much nicer....
itr1244
Mar 18, 2007 11:55 AM
boosted_zc
Apr 22, 2004 01:21 PM
speedymon
Nov 10, 2003 04:50 AM
lowboost civ
Apr 23, 2003 06:46 PM
Charlie Moua
Sep 6, 2002 12:16 PM
