Greddy Type s Question
Old Mar 19, 2006 | 05:27 AM
musclefella's Avatar
Default Greddy Type s Question
I have a 10psi spring in my tial 38mm. When i turn the boost controller off it boosts 10psi, so far so good. I've turned the Low boost **** all the way to minimum and the car boosts 10psi wich is fine with me. The manual says max low boost is 3rd notch high boost. But when i up even 1 notch on highboost the car boosts towards 25psi. I tried the 3rd notch thing and car still boosts well over 20psi. I thought it might be a boost spike but it's not.
If i turn the low boost **** up 6 clicks it boosts 16 psi nicely and i can even get 20 psi nicely with playing with low boost setting.
I wanted 10psi low boost and 16psi highboost, but notting seems to work. What am i missing here?? Do i need a 4 psi spring in the tial??
Any advice welcome
Modified by musclefella at 1:11 AM 3/20/2006
Old Mar 19, 2006 | 03:08 PM
Default Re: Greddy Type s Question (musclefella)
ttt
Old Mar 26, 2006 | 06:21 AM
Silverbullet86's Avatar
whats this have to do with your blow off valve at all?
what type of boost controller is it, you weren't very specific at all.
Old Mar 26, 2006 | 06:21 PM
Default Re: Greddy Type s Question (Silverbullet86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverbullet86 &raquo;</TD></TR><TR><TD CLASS="quote">whats this have to do with your blow off valve at all?
what type of boost controller is it, you weren't very specific at all.</TD></TR></TABLE>
It has nothing to do with my Blow off valve at all, maybe you didn't read it correctly. I have a Greddy profec Type-S Boost controller and i can't seem to adjust the high boost setting. 10 psi is low boost with the low boost **** at the min position, but if i turn the high boost **** even 1 click it shoots to 20 plus psi.
Question is; Do i need a softer spring for the wastegate wich now has a 10psi spring, to get to about 15 psi highboost??
94turboeg
Aug 13, 2007 12:08 AM
integraRS-T
Jul 8, 2007 03:56 PM
StolenTeg
Sep 8, 2005 04:17 PM
all go teg
Aug 5, 2005 04:56 AM
01geeser
Nov 22, 2002 02:29 AM
