QTP e cutout?...
have anyone have any experience or tried one the QTP e cutout before?...just need to know if they perform as good as the dmh e cutouts such as the opening and closing of it and if they open all the way...ive heard some e cutouts doesn't open all the way like they suppose to...
http://www.quicktimeperformanc...&p=25
a friend has one on his 240. it worked till he hit something on the road then it broke... but that's not really the qtp's fault.
personally, i run a dmh and i love it, never had a probelm yet, and it fully opens and closes! quickly too.
when i was researching cutouts, i read that the qtp break more often... idk.
I use one and give it more attention than anything else on the car. It leaks, so the fix is high temp RTV to help it seal. It sticks sometimes because of the RTV and as of late, I have to tap the motor while activating the switch to make it work, I believe it's toast, but having one is fun when it's working.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elevatedj32 »</TD></TR><TR><TD CLASS="quote">I use one and give it more attention than anything else on the car. It leaks, so the fix is high temp RTV to help it seal. It sticks sometimes because of the RTV and as of late, I have to tap the motor while activating the switch to make it work, I believe it's toast, but having one is fun when it's working.
What brand do you have?
</TD></TR></TABLE>What brand do you have?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pootie »</TD></TR><TR><TD CLASS="quote">i heard there's a break-in procedure for the qtp, so that it seals properly. Is this true? If so, what is the method? Thanks</TD></TR></TABLE>the DMH one says to run the car with it closed on first start-up. and then drive it a little to seal it then your set.
Quote, originally posted by MidShipCivic »
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbochargeb18c »</TD></TR><TR><TD CLASS="quote">cool thanks guys...i think im gonna get the dmh one then...can afford any f*cks...</TD></TR></TABLE>
run the 4" exhaust fawker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 »</TD></TR><TR><TD CLASS="quote">
too rich for my blood...dont have the kind of money like you
</TD></TR></TABLE>too rich for my blood...dont have the kind of money like you
I buy my parts with Food Stamps
</TD></TR></TABLE>I buy my parts with Food Stamps
**** i used wic...
</TD></TR></TABLE>**** i used wic...
off topic but has anyone tried the VES (Virtual Exhaust System)
http://www.atpturbo.com/root/r...4.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOON_BeIgHtEeNsEe »</TD></TR><TR><TD CLASS="quote">off topic but has anyone tried the VES (Virtual Exhaust System)
Hmm exhaust just loves making 90 degree angles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fox three »</TD></TR><TR><TD CLASS="quote">DMH is generally regarded as the best electric cut out around here. I've never had a problem or seen a problem with them.
QTP's however have leaked on a friends fbody.</TD></TR></TABLE>
where to buy the "DMH?"
also this doesnt even open till a few psi of boost, which to me is not where i want it to open, i want it to be open when im trying to get into boost. not when i am alrady there
turnsignalandy
16
Apr 10, 2008 05:58 AM
RR98ITR
Dec 3, 2005 05:33 PM
