Going for a 75 Shot! What do i need to DO
Old Mar 21, 2006 | 10:42 PM
mugenhatch92's Avatar
Default Going for a 75 Shot! What do i need to DO
Well i am going to jump on the bottle just for a little while, while i am saving my money for my cams, and turbo setup..
Anyway... let here what i should do, to make this safe, and reliable..
Thanks Chase
Old Mar 21, 2006 | 10:50 PM
f1 vtec's Avatar
Default Re: Going for a 75 Shot! What do i need to DO (mugenhatch92)
Give us some more info on your setup is the Nos a dryshot, wet shot or direct port?
Old Mar 21, 2006 | 10:51 PM
definatly a wet shot... on a GSR with IM, itr header... blah blah..
stock internals, and stock head...
so 75 shot max is what ill run, but i am needing info on timing, plugs, ect..
Thanks
Old Mar 21, 2006 | 11:29 PM
crucian's Avatar
Default Re: (mugenhatch92)
I ran BKR7es on stock timing no problems. A window switch is a must!
Old Mar 21, 2006 | 11:59 PM
a window switch??
what the hell is that? lol
Old Mar 22, 2006 | 04:16 AM
Jay_Sensing's Avatar
It is an electronic box that turns the spray on and off and certain rpms.
BUY ONE!!!!!!
I have sprayed about 12 cars, maybe more and I never hurt a motor without one and I didn't bother spending the money on one.
Well the one incident of losing traction out of the hole and hitting the limiter on the nitrous and I burnt 2 valves and killed the #2 piston. Several days of down time waiting for parts and two times through the motor to find all the problems were not worth the 120 bucks I saved by not doing it.
Old Mar 22, 2006 | 04:28 AM
crucian's Avatar
http://www.msdignition.com/rpm_7.htm The window switch is part #8956.
Old Mar 22, 2006 | 05:27 AM
quikcivic's Avatar
Default Re: (crucian)
dont mean to thread jack but.... can you run a 75 shot on stock timing? i thought u got to retard your timing? What about race gas if u run 110 octaine can u retain the stock timing so u wont lose performance all motor? Also for the last question how much do u gap ur plugs for nitrous?
-D
Old Mar 22, 2006 | 05:56 AM
crucian's Avatar
Default Re: (quikcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikcivic &raquo;</TD></TR><TR><TD CLASS="quote">dont mean to thread jack but.... can you run a 75 shot on stock timing? i thought u got to retard your timing? What about race gas if u run 110 octaine can u retain the stock timing so u wont lose performance all motor? Also for the last question how much do u gap ur plugs for nitrous?
-D</TD></TR></TABLE> Well let me put it like this. I experimented with it. I have an MSD digital 6. I started off with 2 degrees retard on spray and kept adding timing until I got back to 0 degrees retard on spray. Nothing ever happened for as long as I was running nitrous. That was almost a year. Took the car to my automotive school for a class project on doing compression and leak down tests on engines. Engine passed the both tests as if the engine was brand new. I think I gapped my plugs to .45 or something. I can't remember. Been a while. I didnt run race gas. Just pump gas.
Old Mar 22, 2006 | 06:31 AM
quikcivic's Avatar
thanks alot, iam running 80 shot then cause i have direct port and just running race gas with colder plugs, iam not running the car on the streets just at the track well see what happens
Old Mar 23, 2006 | 07:09 AM
Phase Change Racing's Avatar
With 110 ocatne fuel you should be just fine with stock timing, you could probably bump the timing up a couple degrees if you really wanted. for a 75 shot there really isn't much need to change your plug gap. If you start spraying above 150 or so it would bea good idea to tighten up your gap .004-.006. its not really crucial, it just ensures that your ignition can make the jump through all the stuff in the combustion chamber.
b16bswap
15
Dec 4, 2008 05:39 PM
99hondacura
Feb 25, 2007 11:32 AM
Civic Hybrid
Feb 23, 2007 08:36 AM
exquivical
Jun 30, 2002 01:12 AM
cliqueSI
Aug 12, 2001 06:38 PM
