LS/VTEC BUILD>>!!!!!!
Old Mar 21, 2006 | 09:42 AM
1badda's Avatar
Default LS/VTEC BUILD>>!!!!!!
HEy people i have a 99 b16 head with b18 block. I have a gsr distrubitor with vtec timing belt , water pump . Now i was wondering what else do i need and would it have to be all vtec **** like oil pump, crank gear, and crank pulley?? I will also be using type r cams. Would any cam gear work?? This setups will be use for turbo by the way..
Old Mar 21, 2006 | 09:51 AM
LSVtechnologytur...'s Avatar
Default Re: LS/VTEC BUILD>>!!!!!! (streetaccord)
I used the ls crank gear & pully. Type R cams are great to use w/ boost (or even w/out boost) and as far as i know any b-series vtec cam will work. You need to either tap the back of the block for an oil line to the head, or use an oil sandwich. .. some more little stuff
http://www.c-speedracing.com/h...c.php
Old Mar 21, 2006 | 09:54 AM
1badda's Avatar
would that work knowing i have a vtec timing belt
Old Mar 21, 2006 | 01:35 PM
1badda's Avatar
bump
JDMCIVIC919
May 4, 2012 02:52 PM
Renegade
Feb 13, 2007 08:01 AM
1badda
Mar 21, 2006 01:36 PM
redlineintegra
Oct 6, 2005 10:48 AM
NuclearB18B
Sep 20, 2002 07:50 AM
