anyone have MBC problems over 25psi
Old Mar 19, 2006 | 06:37 PM
Quickgti1.8t's Avatar
Default anyone have MBC problems over 25psi
Basically if i go over 20psi it does some weird things. The needle goes back and forth VERY fast. ay 25psi it worse it goes back and forth like 3-4psi diff. I think its the MBC, do you think a EBC would fix the problem or should i change my wastegate its a 38mm with 1 bar spring. Turbo is a GT35R .63
Old Mar 19, 2006 | 08:41 PM
Default Re: anyone have MBC problems over 25psi (Quickgti1.8t)
Old Mar 20, 2006 | 05:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quickgti1.8t &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Old Mar 20, 2006 | 05:50 AM
non-VTEC's Avatar
what size is the spring in the wastegate?
a MBC sometimes has a hard time controling boost if you try to more than double the spring pressure it was designed for.
Old Mar 20, 2006 | 07:25 PM
Default Re: anyone have MBC problems over 25psi (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">what size is the spring in the wastegate?
a MBC sometimes has a hard time controling boost if you try to more than double the spring pressure it was designed for.</TD></TR></TABLE>
1 bar, i heard it doesn't really matter if u double the pressure of the wastegate spring
Old Mar 20, 2006 | 08:34 PM
Old Mar 20, 2006 | 08:41 PM
Tony the Tiger's Avatar
1 bar, i heard it doesn't really matter if u double the pressure of the wastegate spring</TD></TR></TABLE>
Boost is going to become unstable if you are running a lot more boost than the base WG spring pressure. Try to swap to a higher PSI spring, closer to the boost you are intended to run
Old Mar 21, 2006 | 10:50 PM
Default Re: anyone have MBC problems over 25psi (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">
Boost is going to become unstable if you are running a lot more boost than the base WG spring pressure. Try to swap to a higher PSI spring, closer to the boost you are intended to run </TD></TR></TABLE>
wouldn't part throttle be crappy with a bigger spring
Old Mar 22, 2006 | 01:39 AM
wouldn't part throttle be crappy with a bigger spring</TD></TR></TABLE>
Heavier spring = less wastegate movement.
If part throttle becomes crappy, your engine needs some love... Get it tuned.
Old Mar 22, 2006 | 07:09 PM
If part throttle becomes crappy, your engine needs some love... Get it tuned.</TD></TR></TABLE>
hmmmm might order a small spring to make it around 18psi daily
Old Mar 22, 2006 | 07:18 PM
Bailhatch's Avatar
I agree that you may be too far over the WG spring. It could also be a combination of the WG design and boost controler design too.
The ball and spring/bleeder style boost controlers that TXS sells work awesome to over 30psi if the rest of your hardware it up to par.
Old Mar 22, 2006 | 09:50 PM
Default Re: anyone have MBC problems over 25psi (Bailhatch)
right now i have a spring/ball with bleeder. I had a TXS and it sucked even more then this one
Old Mar 22, 2006 | 11:15 PM
Dunc's Avatar
BCICAN
You shouldn't be boosting like 20psi+ boosting in part throttle anyways
Old Mar 24, 2006 | 07:38 PM
tried running off the wastegate and it was smooth then did it again and after 6k rpm it was steddy again
jdm_dc_fan
Aug 11, 2008 03:03 PM
truesleeper
Nov 7, 2004 03:37 PM
yusoslo
Apr 22, 2004 10:53 AM
sirb18a
Oct 19, 2003 01:49 PM
JrCRXHF
Jul 20, 2003 11:06 AM
