Problems with my new turbo setup!
Old Mar 20, 2006 | 01:57 PM
lecy55's Avatar
Default Problems with my new turbo setup!
So I just installed a TB0357 Saab Turbo w/ a/r .42 compressor, a/r .48 turbine, and .45 trim Manifold w/ external wastegate mount Tial Wastegate at 11.6psi. and a Large Front Mount Intercooler
So my problem is that I am new to the whole turbo thing and I seem to only be getting about 3 psi. and lacking the HP gains that I expected. I was wondering if anyone knew what my problem is or if there is a way to get more boost?
Old Mar 20, 2006 | 02:00 PM
Fitti's Avatar
Default Re: Problems with my new turbo setup! (lecy55)
check all your connections make sure you don't have a coupling blown off as well as vaccum leaks. The front mount may be to big and you are seeing excessive amounts of pressure drops through it.
What size motor is this own?
Old Mar 20, 2006 | 02:16 PM
mrbsponge's Avatar
Default Re: Problems with my new turbo setup! (Fitti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fitti &raquo;</TD></TR><TR><TD CLASS="quote">check all your connections make sure you don't have a coupling blown off as well as vaccum leaks. The front mount may be to big and you are seeing excessive amounts of pressure drops through it.
What size motor is this own?</TD></TR></TABLE>
exactly, sounds like you have a boost leak somewhere, or you have a large exhaust leak before the turbo
Old Mar 20, 2006 | 02:20 PM
lecy55's Avatar
Default Re: Problems with my new turbo setup! (mrbsponge)
The motor is a D16Z6
Old Mar 20, 2006 | 02:32 PM
TurboTagTeam's Avatar
It's definatly not a pressure drop in your intercooler. Sounds like a boost leak to me. If it were an exhaust leak you would be able to hear it.
92tealhatch
Jan 16, 2012 10:21 AM
speedlabx2005
Jan 14, 2008 06:31 PM
slo88hatch
Mar 22, 2007 01:53 PM
blak golf
Feb 12, 2007 05:40 AM
Topdawgg
Oct 15, 2006 02:25 AM
