HELP!! boosted msd ignition problems - sputtering.. misfiring.. cutting out~
Old Mar 18, 2006 | 09:09 PM
92lstcvc's Avatar
Default HELP!! boosted msd ignition problems - sputtering.. misfiring.. cutting out~
recently my 300hp b18b turbo civic has been giving me some troubles
ONLY at a constant rpm or high end rpm, will it misfire a little
after moderate misfiring the engine decides to die - this has happened three times.. - i let the engine sit a while and she fires up again
i have power from the battery~
MOST of the time she works perfect ..
the stock distributor was modified for a msd blaster 2 external coil
the coil wire isnt in its best condition and the dissy terminal is rather ghetto/loose and im wondering if that would be the problem??
i have a new msd distributor cap, msd rotor, spark plug wires, and ngk bkr7e's on the way...
Modified by 92lstcvc at 12:11 AM 3/19/2006
Old Mar 18, 2006 | 10:31 PM
turtle-eg's Avatar
Default Re: HELP!! boosted msd ignition problems - sputtering.. misfiring.. cutting out~ (92lstcvc)
I know most people here would tell you to get rid of the MSD, but I don't think that's your problem.. check your ignition module.
Old Mar 18, 2006 | 11:52 PM
92lstcvc's Avatar
Default Re: HELP!! boosted msd ignition problems - sputtering.. misfiring.. cutting out~ (turtle-eg)
doesn't the blaster 2 external coil bypass the stock ignition module?
Old Mar 19, 2006 | 07:00 AM
coneheadsracing's Avatar
get all your wiring up to par. Loose wires, corroded anything like that will cause you issues.
Xtreme_Cause
18
Jun 22, 2020 08:27 AM
Hondero_PR
Sep 12, 2011 03:03 PM
Rodzknight
Jul 3, 2006 01:02 PM
92lstcvc
Mar 18, 2006 09:09 PM
CruiseControl
Dec 9, 2005 10:40 PM
