SOMEONE ANSWER ME THIS ONCE AND FOR ALL!!!!!!!?????
Old Mar 20, 2006 | 12:07 PM
mrrugsr's Avatar
Default SOMEONE ANSWER ME THIS ONCE AND FOR ALL!!!!!!!?????
OK, i have a 1995 GSR and im almost done with my turbo project. Im buying Precision 550cc injectors and ive heard from many people that I need a resistor box and then others will say i dont need a box since they are low impedance. Whats the deal guys, anyone know?
Also they should fit into the Stock clips too right?
Old Mar 20, 2006 | 12:08 PM
b18bturbo's Avatar
Default Re: SOMEONE ANSWER ME THIS ONCE AND FOR ALL!!!!!!!????? (mrrugsr)
if the injector is low imp you will need resistor box if the injector is high imp you can use stock driver to fire the injectors
by the way the 550cc are low imp injectors from precision
Old Mar 20, 2006 | 12:11 PM
mrrugsr's Avatar
so im gonna need one? any idea how to wire it up and where i can get the box?
Old Mar 20, 2006 | 12:14 PM
coneheadsracing's Avatar
Default Re: (mrrugsr)
junkyards, and ebay... also there should be write ups covering it, might check ef-honda if you don't find any here.
boostedcivicsir's Avatar
Mr. Badwrench
first ohm the injectors to see if you need one or not. if they are 2-3 ohm, you need a resistor box. if they are 12-13 ohm, then you dont.
Old Mar 20, 2006 | 12:19 PM
mrrugsr's Avatar
HOW DO U OHM THEM
Old Mar 20, 2006 | 12:22 PM
slooogsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrrugsr &raquo;</TD></TR><TR><TD CLASS="quote">HOW DO U OHM THEM</TD></TR></TABLE>
u need a digital multimeter that measures resistance in ohms, symbol that looks like a horshoe....... touch the leads with your injectors to find out the resistance......
Old Mar 20, 2006 | 12:28 PM
Adam.C's Avatar
i would use inline resistors intead of a resistor box, seen resistor boxes go bad because u really never know the condition of one, can cause injectors to fail and kill an engine, i would use inline resistors if u can
Old Mar 20, 2006 | 12:39 PM
slooogsr's Avatar
Default Re: SOMEONE ANSWER ME THIS ONCE AND FOR ALL!!!!!!!????? (orangerex04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangerex04 &raquo;</TD></TR><TR><TD CLASS="quote">i would use inline resistors intead of a resistor box, seen resistor boxes go bad because u really never know the condition of one, can cause injectors to fail and kill an engine, i would use inline resistors if u can</TD></TR></TABLE>
i was thinking of doing the same thing, would this be an easier installation as well??
any links regarding this topic?
Old Mar 21, 2006 | 05:03 AM
mrrugsr's Avatar
YEA, ANYTHING ON INLINES?^
Old Mar 21, 2006 | 06:11 AM
elpiar's Avatar
Both inline and resistor box will work fine. I used resistor box because I figured honda make them with certain industrial standard while radioshack might make them for hobby purposes. Plus, the resistor box acts as a good heatsink for the heat dissipation and protection.
Old Mar 21, 2006 | 06:24 AM
Mr. Badwrench
Default Re: (elpiar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elpiar &raquo;</TD></TR><TR><TD CLASS="quote">Both inline and resistor box will work fine. I used resistor box because I figured honda make them with certain industrial standard while radioshack might make them for hobby purposes. Plus, the resistor box acts as a good heatsink for the heat dissipation and protection.</TD></TR></TABLE>
plus a 10W 10Ohm resistor is frickin big. i think the box is alot cleaner.
Old Mar 21, 2006 | 06:51 AM
mrrugsr's Avatar
STILL HAVENT FOUND WHERE 2 GET A RES. BOX
Old Mar 21, 2006 | 07:03 AM
drintegra's Avatar
These injectors should wire up the same as DSM injectors here are some links
https://honda-tech.com/zerothread?id=691345
https://honda-tech.com/zerothread?id=195834
http://www.geocities.com/uncgo....html
There is another way to get wire them up without hte resistor box, you need individual resistors wired between the injector wires. The resistors are like 2-5 bucks at Radio Shack. If you can't find it here let me know.
Old Mar 21, 2006 | 08:38 AM
elpiar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrrugsr &raquo;</TD></TR><TR><TD CLASS="quote">STILL HAVENT FOUND WHERE 2 GET A RES. BOX</TD></TR></TABLE>
http://motors.search.ebay.com/...Z6000
BTW, do you mean anything by writing in all caps? that can be misunderstood you know
especially there are pretty sensitive people here at HT
Old Mar 21, 2006 | 08:41 AM
mrrugsr's Avatar
sorry about the caps. i work with AutoCAD 24/7 and i forget to turn them off every now and then, my bad
Tanks for the link
Old Mar 21, 2006 | 08:42 AM
HondaHead211's Avatar
couldnt he just go buy a set of saturated injectors this way he can bypass all that resistor box stuff. i thought that only peak and hold injectors needed a resistor box and saturated injectors were basicaly just "plug and play" with the additionof OBD clips in some instances??????
Old Mar 21, 2006 | 08:43 AM
mrrugsr's Avatar
must it be from a TURBO DSM?
Old Mar 21, 2006 | 09:16 PM
elpiar's Avatar
if you want to go cheap you can get the blue tops 450
Old Mar 22, 2006 | 01:20 AM
raceACCORDingly's Avatar
Default Re: (HondaHead211)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaHead211 &raquo;</TD></TR><TR><TD CLASS="quote"> buy a set of saturated injectors</TD></TR></TABLE>
Old Mar 22, 2006 | 07:57 AM
mrrugsr's Avatar
i can get 550 peak and hold for $275, while the saturated ones(higher cc) are MORE $. is it really worth the jump in price?
Old Mar 22, 2006 | 09:18 AM
m R g S r's Avatar
copyin my sn?
GRRRRRRRR
Old Mar 22, 2006 | 09:23 AM
Mr. Badwrench
if your car is obd1 or newer, just get the saturated ones. you wont need a box, but if you necessitate higher than 750's, peak and holds are your only option.
Old Mar 22, 2006 | 10:08 AM
mrrugsr's Avatar
necessitate higher than 750's.......?
Old Mar 22, 2006 | 10:11 AM
mrrugsr's Avatar
Default Re: SOMEONE ANSWER ME THIS ONCE AND FOR ALL!!!!!!!????? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">copyin my sn?
GRRRRRRRR </TD></TR></TABLE>
MRRUGSR IS ASKING THE QUESTION: "ARE YOU GSR"
MY ORG SN ON OTHER SITES IS RUGSR. IT WAS TAKEN HERE SO I MODIFIED IT.
