Is a Catch Can necessary.................
Old Mar 19, 2006 | 05:36 AM
Mugencrxsir1's Avatar
Default Is a Catch Can necessary.................
Is a catch can really necessary for my turbo ls/vtec? I'm still a little confused on what exactly the catch can is used for? I've seen a lot of set-ups with catch cans and a lot without. Again my power goal is 350-400hp.
Old Mar 19, 2006 | 06:14 AM
Default Re: Is a Catch Can necessary................. (Mugencrxsir1)
anyone.............
Old Mar 19, 2006 | 06:47 AM
ImportMotorSpec's Avatar
Are you talking about a catch can, or a breather can.
A catch can is for liquids, ie radiator overflow.
The breather can is the one with a filter on top that allows crank case or valve cover to release the pressure that builds up in either part. It takes vapors and condenses them back, usually gas vapors that would end up in your oil. So i didn't, or don't on any cars, plumb the return line back into the system.
Old Mar 19, 2006 | 07:10 AM
ek_chris's Avatar
Default Re: Is a Catch Can necessary................. (ImportMotorSpec)
https://honda-tech.com/zerothread?id=1199935
Old Mar 19, 2006 | 07:12 AM
Default Re: Is a Catch Can necessary................. (ek_chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportMotorSpec &raquo;</TD></TR><TR><TD CLASS="quote">Are you talking about a catch can, or a breather can.
The breather can is the one with a filter on top that allows crank case or valve cover to release the pressure that builds up in either part. It takes vapors and condenses them back, usually gas vapors that would end up in your oil. So i didn't, or don't on any cars, plumb the return line back into the system. </TD></TR></TABLE>
Thanks for a great explaination and yes I was talking about a breather can. thanks
JDMCIVIC919
May 28, 2012 10:24 PM
JMinSi2000
Nov 4, 2004 09:33 AM
JICEK9
Nov 25, 2003 05:55 AM
BoostedGSRBubble
Aug 12, 2003 12:58 AM
RyanEJ8
May 28, 2003 11:18 AM
