hesitation in mid RPM range
SO i just recently put this turbo **** in my car but cant seem to figure this out...
I have the SAFC hack ( I know its shitty dont tell me) but it works...I have 450 injectors with the resistor box...basicly i know everything is correct.
I have the "check valves trick" hooked up right now for the time being....I have read in an old post you cant do the check valve trick on the SAFC. True or not true?
Between idle and 3g everything runs smoothly 3-5 sounds like its runnin on 2 cylinders then when i hit 5 pulls like a champ. Is it the SAFC that needs to be played with or is it something else that im missing?
Thanks,
TS
Thanks,
TS
