Turbo Coolant Question
Old Jul 24, 2006 | 10:51 AM
SlowSOHC-T's Avatar
Default Turbo Coolant Question
Ok guys i did some searching and couldn't find anything, so i need some help. I just picked up a Air Research T3 off a Saab. I can't find any info on the coolant lines. I know i need to run them to keep the life of the turbo, but i have one of the coolant lines just not the other. I was wondering if anyone knew of a company that made aftermarket lines for them? If so were can i get them and how much.
I don't see many honda's running the coolant and oil setup on there turbo's so searching for this info has been a bit of a tough one. So any info you might have would work great. Thanks alot
Old Jul 25, 2006 | 05:57 AM
SlowSOHC-T's Avatar
Nobody?
Old Jul 25, 2006 | 05:59 AM
redzcstandardhatch's Avatar
something different
just figure out what kind of fitting it is. it is usually some sort of pipe-thread, or whatever. or go to the junkyard and find the factory fittings.
garrett journal bearing turbos used a couple different sizes of fittings for coolant.
i highly recomend running the coolant lines. i always have.
Old Jul 25, 2006 | 06:01 AM
BoostedEG6's Avatar
Default Re: (redzcstandardhatch)
make your own lines....
Old Jul 25, 2006 | 06:44 AM
SlowSOHC-T's Avatar
I found some, thanks alot
Topdawgg
Feb 12, 2007 08:41 PM
RTW DC2R
Jun 3, 2006 07:20 PM
Kimbo
May 6, 2003 11:48 AM
