2000 CFM fan update
Old Jul 21, 2006 | 07:07 PM
Boostage's Avatar
Default 2000 CFM fan update
For those that remember this thread.
https://honda-tech.com/zerothread?id=1688628
Well I went and bought the fan, and I still dont know if it's exactly 2000 cfm but it DID fix my overheating problems. my intercooler blocking airflow is no longer an issue, the fan is POWERFUL, I beat the hell out of the car for an hour, and ran into plenty stop and go traffic, and the needle doesnt move. if you have a Turbo car with a big intercooler I highly recommend this fan. I am very happy!
Its a 12 Inch S-blade fan that supposedly flows 2000 CFM. your car will NOT run hot with this bad boy.
Old Jul 21, 2006 | 07:35 PM
non-VTEC's Avatar
Default Re: 2000 CFM fan update (Boostage)
nice find!
Old Jul 21, 2006 | 07:37 PM
komat's Avatar
were you overheating on the highway ?
Old Jul 21, 2006 | 07:49 PM
nowtype's Avatar
Default Re: 2000 CFM fan update (komat)
I personally suggest measuring your radiator. I have an OEM type Del Sol dual core radiator which I was able to put a 14" slim line fan on. It flows significantly more air than 12" fans and only costs a couple bucks more. People sticking 12" fans when you can fit 14" fans are silly.
Old Jul 21, 2006 | 08:03 PM
EK k kay's Avatar
Default Re: 2000 CFM fan update (nowtype)
Those fans are great. I have two of the 12" ones from b18bturbo. I use one as a puller on my radiator and the other as a pusher for my ac on my turbo setup. They blow a hell of a lot of air. 14" fans will fit easily on 1/2 size radiators if you mount them as pullers. As pushers there is a limited amount of room to work with. Pullers are better anyway.
Here are 14" fans: http://cgi.ebay.com/ebaymotors...EITEM
Old Jul 21, 2006 | 08:08 PM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">were you overheating on the highway ?</TD></TR></TABLE>
No, just in traffic.
Old Jul 21, 2006 | 08:11 PM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype &raquo;</TD></TR><TR><TD CLASS="quote">I personally suggest measuring your radiator. I have an OEM type Del Sol dual core radiator which I was able to put a 14" slim line fan on. It flows significantly more air than 12" fans and only costs a couple bucks more. People sticking 12" fans when you can fit 14" fans are silly.</TD></TR></TABLE>
Funny u should say that because I compared the old fan (10" slim fan) with teh new 12 inch and the diameter wa steh exact same, I was so pissed. I guess they measure the blades, and being an "S" technically it 12 inches if you were to make the blades straight. I have a PWR radiator and I measured it and had an extra inch or so all around, so when the new fan came and it was the same size. I was upset, but it actually works, so now I dont care.
KevinEF7
Dec 7, 2012 12:17 PM
Mr.Death
Oct 8, 2010 04:16 PM
the.hamburglar
Mar 17, 2007 08:03 AM
Boostage
Jul 21, 2006 07:08 PM
budget
Apr 8, 2005 10:46 PM
