Boost Spikes???
Old Jul 26, 2006 | 05:30 AM
DrivinVtec's Avatar
Default Boost Spikes???
Im running open WG for exhaust an boost.(7lbs) I dont even have a pipe for the WG right now. Gehtto I know. But anyways I was lookin, im boostin close to 9psi. why is this since I have a 7psi spring?? Im also running open DP.
-Open DP
-Open exhaust on WG(no Pipe)
-7 lbs sping
Got any Ideas???
Old Jul 26, 2006 | 05:35 AM
BoostedEG6's Avatar
Default Re: Boost Spikes??? (DrivinVtec)
English?
Old Jul 26, 2006 | 05:39 AM
DrivinVtec's Avatar
Default Re: Boost Spikes??? (BoostedEG6)
makes sence to me.
Old Jul 26, 2006 | 05:46 AM
BoostedEG6's Avatar
are you saying that you are spiking to 9psi but your running off a 7psi spring? and you dont know why?
Old Jul 26, 2006 | 05:49 AM
DrivinVtec's Avatar
correct...but im thinking its becuse of the open DP?
Old Jul 26, 2006 | 05:52 AM
BoostedEG6's Avatar
where do you have the vac line for the wastegate running to? and where is the line for the Boost gauge going to?
Old Jul 26, 2006 | 05:56 AM
DrivinVtec's Avatar
line to the WG to the Turbo it self. the the gauge is off the manifold
Old Jul 26, 2006 | 05:59 AM
BoostedEG6's Avatar
what kind of gauge do you have and is it working correctly? Reason I ask is because you should be reading a lower amount of boost since you wg line is running to the turbo and you have a pressure drop from the turbo to the manifold.
Old Jul 26, 2006 | 06:16 AM
DrivinVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of gauge do you have and is it working correctly? Reason I ask is because you should be reading a lower amount of boost since you wg line is running to the turbo and you have a pressure drop from the turbo to the manifold.</TD></TR></TABLE>I have a phantom auto meter gauge. i see what your saying. hummm..it was cool out this morrning. air is more denser maybe caused it to boost more?
should i have the WG plugged into the manifold? I would think the way i have it setup right now it would be best?
Old Jul 26, 2006 | 06:28 AM
BoostedEG6's Avatar
it doesnt matter either way that you put the vac line. The way you have it now is fine. If you placed the vac line at the manifold just means that when the mani is at the right pressure it would open the wg vice when the pressure is at the turbo. Do you understand what I am saying?
Old Jul 26, 2006 | 06:34 AM
DrivinVtec's Avatar
yeah i go u.
I think between open DP an Haven it cool outside caused it to spike/creek. i need to to get the exhaust on.
Old Jul 26, 2006 | 04:48 PM
dpetro1's Avatar
is it spiking or creeping or both?
Old Jul 26, 2006 | 04:52 PM
kraig8's Avatar
your WG diaphram might be dirty or clogged with carbon. it could be stickin cuasing it to spike.
Old Jul 26, 2006 | 04:54 PM
RedR's Avatar
Default Re: (kraig8)
what turbo is it and manifold?
Old Jul 26, 2006 | 04:56 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedR &raquo;</TD></TR><TR><TD CLASS="quote"> what turbo is it and manifold? </TD></TR></TABLE>
+1
Old Jul 26, 2006 | 05:00 PM
DrivinVtec's Avatar
Herms Fab log mani with a t3/t4oe 60 trim. everything is new. usen a tial 38mm wg
Old Jul 26, 2006 | 06:01 PM
DrivinVtec's Avatar
anyone else thinks its still the open dp thats causen it to boost 10psi?
DrivinVtec
Sep 9, 2007 06:27 PM
rickturboteg
Aug 7, 2006 04:36 PM
TreeToTall
Apr 4, 2005 03:55 AM
killa_lude
Oct 13, 2003 06:16 PM
Turbocivic94
Aug 7, 2003 05:39 AM
