450 DSM injector question an timming
Old Jul 24, 2006 | 12:00 AM
DrivinVtec's Avatar
Default 450 DSM injector question an timming
Crome says them injectors are max out on 10psi on my car. is that right. i dont think so. Im only running 7psi so im not trying to stress the injectors out.
also im running 20 degrees timming at WOT on &psi. That should be pretty safe corrrect?
I have a 5th gen lude.
Old Jul 24, 2006 | 12:17 AM
mtber's Avatar
Default Re: 450 DSM injector question an timming (DrivinVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec &raquo;</TD></TR><TR><TD CLASS="quote">Crome says them injectors are max out on 10psi on my car. is that right. i dont think so. Im only running 7psi so im not trying to stress the injectors out.
I have a 5th gen lude.</TD></TR></TABLE>
I would back your igniton timing down a bit until you get on a dyno.
Your duty cycle report in crome is probably off.
As long as your not hitting any lean spot near your supposed 100% duty cycle values, you should be ok until you get on the dyno.
I would judge your injector's duty cycle by how much whp/tq you are making
Old Jul 24, 2006 | 05:36 AM
DrivinVtec's Avatar
u think it need more timming?
HondaKid936
Nov 13, 2008 07:16 AM
rice a roni
May 20, 2006 02:32 AM
jmac
Feb 11, 2005 08:15 AM
thatbluecrx
Nov 10, 2004 09:27 PM
arsenaldragster
Apr 22, 2003 07:09 PM
