Searched. Water Pump Help
Old Jul 25, 2006 | 09:35 AM
Rikter's Avatar
Default Searched. Water Pump Help
Hi Guys,
I recently blew up my LS Vtec High compression engine (11.5:1) due to various reasons that i won't get into.
I am rebuilding my engine. B18A1 block, B16A1 head. JE low compression pistons, forged eagle rods, type R cams, aem adjustable cam gears, Hondata s200, full msd, arp headstuds, sir trans, yadda yadda.
For a turbo I'm running a T3 super 60 off of a 2.5L mustang. Tial 38mm wastegate, 2.5inch downpipe, jrc intercooler, greddy type-s blow off valve, etc. Looking for a tune of around 14-15psi (stock sleeves). Due to a custom install and fabrication in my car I was able to keep the full sized radiator to help with cooling.
Car is a '90 integra. The question I have is:
Do I need to upgrade my water pump to say, a Type R, GSR, B16DelSol. Basically to an engine's that had Vtec?
-Rik
Old Jul 25, 2006 | 09:53 AM
BoostedEG6's Avatar
Default Re: Searched. Water Pump Help (Rikter)
ummmm all water pumps are the same the only difference is the number of teeth where the timing belt goes.
Old Jul 25, 2006 | 09:54 AM
Rikter's Avatar
Oh... I heard some flow more than others?
-Rik
Old Jul 25, 2006 | 10:02 AM
BoostedEG6's Avatar
Default Re: (Rikter)
both the GSR and Type R are the same part number from Acura
They all flow the same..... think about it.... your timing belt is what drives the water pump. How is one going to flow more than the other? they are all shaped the same on the inside
julianbc2
Apr 4, 2010 11:59 AM
1slowhatchie
Mar 17, 2005 07:50 PM
MiKeAhOwSkI
Dec 30, 2004 04:02 AM
ef-you
Aug 6, 2004 06:17 AM
dclub01
Apr 5, 2003 01:50 PM
