What compression i should be getting with 9:1 pistons ??
Old Jul 21, 2006 | 09:11 PM
Cyber ITR's Avatar
Default What compression i should be getting with 9:1 pistons ??
hi, i just wondering im about to do compression check on my built engine, i would like to know what compression usually a healty built engine with 9:1 pistons should be getting, with stock head
thanks
Old Jul 21, 2006 | 10:31 PM
rmcdaniels's Avatar
Default Re: What compression i should be getting with 9:1 pistons ?? (Cyber ITR)
It varies, depending on a number of factors, including cam profile/timing. It should probably be over 150 and the numbers should be within 10% of each other.
Old Jul 21, 2006 | 10:44 PM
B18C1CYA's Avatar
about 160-190 psi , wot and crank it until the gauge dont climb no more
Old Jul 22, 2006 | 12:14 AM
Cyber ITR's Avatar
Default Re: What compression i should be getting with 9:1 pistons ?? (B18C1CYA)
sweet az, thanks guys
Old Jul 22, 2006 | 01:51 AM
riceball777's Avatar
1 get 180 psi with arias 84mm 9:1 pistons
Old Jul 24, 2006 | 09:22 PM
Cyber ITR's Avatar
Default Re: What compression i should be getting with 9:1 pistons ?? (riceball777)
just did my compression test, 3 cylinders on 190psi and 1 cylinder is on 200psi
is that ok ???
Old Jul 24, 2006 | 09:31 PM
96 GSR-T's Avatar
Im at 190-200 on an 8.8:1.... you are fine.
Old Jul 24, 2006 | 10:17 PM
jdmbb6-t's Avatar
im between 160-170 on my 9.1 h22.
Old Jul 24, 2006 | 11:10 PM
Cyber ITR's Avatar
Default Re: (jdmbb6-t)
sweet az, thank you sir
boostedteg4dr
Jan 24, 2009 03:52 PM
Quade
Apr 5, 2005 03:12 PM
B20luda
Jun 8, 2004 08:20 PM
JDM 007
Jan 24, 2003 01:08 PM
