Greddy Rebuild Kit?
Old Jul 25, 2006 | 08:38 AM
easymac's Avatar
Default Greddy Rebuild Kit?
I've got a Greddy kit that's got some bad seals, and bearings. I was wondering if anybody knew where I could find a rebuild kit for the turbo?
It's greddy's EX kit.
Number on the turbo is: TD04H
I've searched ebay, and google, but haven't found anything, maybe I just suck at the internet.
Thank you.
Old Jul 25, 2006 | 09:49 AM
easymac's Avatar
Default Re: Greddy Rebuild Kit? (easymac)
:BUMP:
Come on, somebody's gotta know this.
Old Jul 25, 2006 | 10:22 AM
oscarmayer's Avatar
do a search on google for tdo4h rebuild and see what you find. might be more helpfull.
knoy place i know around my area is http://www.majesticturbo.com
Old Jul 25, 2006 | 10:27 AM
easymac's Avatar
Default Re: (oscarmayer)
i called them up, they said they don't sell the kit. google finds nothing, ebay finds nothing.
i dont wanna pay $375 to have something done that I can do for $35
Old Jul 25, 2006 | 10:48 AM
BoostedEG6's Avatar
Default Re: (easymac)
http://www.powertechnologies-t....html
call that place and see what they have
Old Jul 25, 2006 | 10:49 AM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by easymac &raquo;</TD></TR><TR><TD CLASS="quote">i called them up, they said they don't sell the kit. google finds nothing, ebay finds nothing.
i dont wanna pay $375 to have something done that I can do for $35</TD></TR></TABLE>
That's because it can't be done for $35. even the rebuild kits themselves are about 100 bucks or so, then it needs to be complete broken down, reassembled, and balanced. You're looking at over $200 + whereever.
Old Jul 26, 2006 | 09:31 AM
JokerX-1.6T's Avatar
dont know if they sell the rebuild kits but they rebuild them @ http://www.turbochargers.com/tech.htm and @ http://linux.forcedperformance...Tcomp and also http://www.zeroturbo.com/Price%20List.htm
Modified by JokerX-1.6T at 1:51 PM 7/26/2006
Modified by JokerX-1.6T at 1:52 PM 7/26/2006
Old Jul 27, 2006 | 10:31 AM
easymac's Avatar
Thank you very much guys.
I'm talking to turbochargers.com right now, and they've said they can do the rebuild, or sell me a kit. ZeroTurbo.com will also sell the kit to me.
My only existing problem is that the person who owned the turbo before me (im kindof salvaging this kit) ruined the oil feed fitting area. Destroyed the threads and then tried to weld it to make it seal.
Check this horrible sight out: http://www.easymac.org/~uminac/fitting/
I might just grind it, drill it, and tap it. But I'm waiting for turbocharger.com to get back to me about if they can replace it, because that's obviously ideal.
Old Jul 27, 2006 | 12:22 PM
damn whoever had that before you should be smacked -
Old Jul 27, 2006 | 12:28 PM
easymac's Avatar
haha truth.
Old Jul 27, 2006 | 03:10 PM
oscarmayer's Avatar
i woudl serosuly not use that housing, iron warps when miss heated. thart means the housing is most likley warped so when you spend all yuo $ on rebuiulding a crappy housing that the oil line is trashed on your going to have possbiel bearing and sealing issues still.
a good sued greddy turbo on ebay goes for around $100-$125ish average. a old one that needs rebuilding is le4ss than that. also a T25 will bolt right up to that manifold. hint hint.
Old Jul 27, 2006 | 03:26 PM
easymac's Avatar
i have trouble thinking it would really warp a turbo. turbos are under extreme heat all the time anyway.
but as for the second part, i'd love to find something like that... can you give me an example? i was searching for the wrong thing on ebay then. i couldn't find it anywhere
Old Jul 27, 2006 | 03:38 PM
nickromeo's Avatar
get a differnt turbo.
if a t25 bolts up to that manifold get a t25 with a t3 compressor on it, i think they call it t28,
not to be confuzzled with the gt28.
Old Jul 27, 2006 | 08:27 PM
easymac's Avatar
Default Re: Greddy Rebuild Kit? (nickromeo)
T25 ? Usually the wastegates for the ones I see are set to 12 psi.. I don't want that much, but I do have the wastegate actuator from my current turbo.. would that work out cool ?
I was looking at this one: http://cgi.ebay.com/ebaymotors...QrdZ1
Old Jul 28, 2006 | 05:13 AM
oscarmayer's Avatar
you can fix that issue. t25 WG are not usually set to 12psi. theya re usualyl set to 7psi. you can find them on volvo cars and sabbs too.
Old Jul 28, 2006 | 07:26 AM
easymac's Avatar
is this a good one though? this will mount right up to the stuff i have ?
http://cgi.ebay.com/ebaymotors...sting
Old Jul 28, 2006 | 07:56 AM
dont quote me on it but I believe that yes it worx I have been looking to swa[ out mine also and was considering going this route also
boost'n
Apr 20, 2007 03:31 AM
greddytunedhatch
Sep 9, 2005 06:35 PM
I Gotta Question
Feb 19, 2004 10:42 PM
SiRocket02
Sep 2, 2003 10:17 PM
