Boost question
Old Jul 22, 2006 | 08:31 AM
civicb18Tkid's Avatar
Default Boost question
i have a eg coupe with a b18b swap with a t3t4 setup. i just got done building the bottom end with JE 8.5:1 pistons, JE rings, locks, pins, Eagle H-Beam rods with ARP rod bolts, ACL bearings, and a Cometic .030 head gasket. i put a fresh head on it with only 55k. also put on a new valve cover gasket and timing belt. ive been talkin around to people to see how much boost i should run and get it tuned for and havent really had to much luck. what im leaning toward is 20 psi because this block is a tank and i definatly think it can hold the pressure and ive read that the hea should be fine. what do you guys think........ 20 psi??????
Old Jul 22, 2006 | 08:33 AM
BoostedEG6's Avatar
Default Re: Boost question (civicb18Tkid)
Stock sleeves? Yes you should be fine to run 20psi with a good tune. I wouldnt try to run 20 on pump gas though.
Old Jul 22, 2006 | 08:36 AM
Default Re: Boost question (BoostedEG6)
yea i was thinkin about that last night. should i go like 15 on pump gas then like 20 on race?? o yea and they are stock sleeves... didnt have the money to buy them
Old Jul 22, 2006 | 08:38 AM
BoostedEG6's Avatar
yeah you will be fine with stock sleeves and 15 pump and 20 race. Just make sure you have a good tune. I know what you mean when I did my first build I was in the same boat
Old Jul 22, 2006 | 08:46 AM
im goin with j-k tuning ....... he had a thing on here not to long ago and i have a couple of buddys who are very happy with his work. its a tune and dyno for $100. you guys have any idea on how much power im gonna be puttings down? my old setup i had a little over 250hp on 5 psi with pump gas so what do you think it will put down with 20 psi on race gas?
Old Jul 22, 2006 | 08:51 AM
BoostedEG6's Avatar
There really isnt a way that you can tell how much power your going to make. I would say mid-high 300's maybe higher
Old Jul 22, 2006 | 09:27 AM
thats what i was thinkin, thanks for the help man
if anyone else has input lmk, thanks
collinsvc15
May 28, 2011 08:27 AM
civic_jdm16
May 20, 2007 11:31 AM
JDM97EK
Dec 18, 2006 02:31 PM
civiwhip
Jun 23, 2005 12:25 PM
iww
May 1, 2002 04:13 PM
