does dry nitrous equal backfire??
Old Jul 24, 2006 | 06:58 AM
0618turbocivic's Avatar
Default does dry nitrous equal backfire??
is dry shot more likely to creat backfire than a wet shot? i have zex kit and have 50 shot in right now...
Old Jul 24, 2006 | 08:12 AM
quicksilver1689's Avatar
i ♥ snails
the buildup of excess nitrous in the plenum can cause backfires.
Old Jul 24, 2006 | 08:16 AM
96 GSR-T's Avatar
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">the buildup of excess nitrous in the plenum can cause backfires.</TD></TR></TABLE>
Old Jul 24, 2006 | 08:27 AM
i know about the build up but i read some places saying dry is safer than wet but than others say diff so im just trying get more opions... i know the wet gives fuel and nitrous which can puddle up excess fuel and nitrous and cause backfire ... and dry shoots just nitrous... in all is anyone running a zex dry kit? is the zex dry kit safe?
Old Jul 24, 2006 | 08:30 AM
RyanEJ8's Avatar
Default Re: does dry nitrous equal backfire?? (0618turbocivic)
Wet single fogger equals nitrous backfire. It takes nitrous and gasoline to create combustion even if that combustion occurs in your intake manifold.
I ran a Zex dry kit with a 75 shot on my D16 for at least 2 years with no problems.
Old Jul 24, 2006 | 08:31 AM
Default Re: does dry nitrous equal backfire?? (RyanEJ8)
so it should be safer with dry shot?
Old Jul 24, 2006 | 08:40 AM
96 GSR-T's Avatar
Correct me if I am wrong, doesnt lugging the engine cause the mixture to puddle, so as long as you are up in the rev range and only engaging WOT, the chances of a backfire are slim to none.
Old Jul 24, 2006 | 09:23 AM
Default Re: does dry nitrous equal backfire?? (96 GSR-T)
cool thanks feels kinda good to get some pos feed instead of all neg... i got kit couple days ago but after few friends talking about backfire kinda got nervous lol but thanks again
Old Jul 24, 2006 | 11:50 AM
tegasaurus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">Correct me if I am wrong, doesnt lugging the engine cause the mixture to puddle, so as long as you are up in the rev range and only engaging WOT, the chances of a backfire are slim to none.</TD></TR></TABLE>
correct!
First hand experience with several nitrous setups. to be honest, the safest and easiest hookup was the zex. I ran it for over 6 months, probably 9 or 10 bottles went by with no problems. NX kit had a couple of intake backfires. pretty scary thing ha.
to help correct the problem of intake backfires on a nitrous setup, don't run it in 5th gear or anything below 4000rpm. if you run nitrous in 5th gear, just plan on rebuilding your motor too. buddy of mine for ***** and giggles wanted to see how fast 5th gear pulled on a 75 wet shot ls/vtec... well, turned out we ended up seeing how quick we could pull the motor
Old Jul 24, 2006 | 12:46 PM
Default Re: does dry nitrous equal backfire?? (tegasaurus)
ha,, yea im using the zex kit...so anything above 4000 and not in 5th gear using wot switch.... k thanks
Old Jul 24, 2006 | 01:10 PM
96 GSR-T's Avatar
I would personally only engage it if it was in VTEC to assure them RPM's are moving as fast as they can.
Old Jul 24, 2006 | 01:30 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">I would personally only engage it if it was in VTEC to assure them RPM's are moving as fast as they can.</TD></TR></TABLE>
You can run it as low as 3k until redline. Just don't hit the rev limiter or misshift.
Old Jul 24, 2006 | 06:25 PM
Default Re: does dry nitrous equal backfire?? (Finest)
what happens when misshift? lol yea its non vtec sohc 1.6... just waiting till winter get laid off so can build up motor for summer again... how it feel with nitrous from 55 shot and up? i never been in car with nitrous or used it, i bought it cause got it at deal..
Old Jul 24, 2006 | 06:27 PM
where do people usually purge at? i was reading onto intercooler to cool it down quick before run.... would help any to get purge into intake filter on turbo? or into turbo screen to cool it down?
Old Jul 25, 2006 | 06:45 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0618turbocivic &raquo;</TD></TR><TR><TD CLASS="quote">where do people usually purge at? i was reading onto intercooler to cool it down quick before run.... would help any to get purge into intake filter on turbo? or into turbo screen to cool it down?</TD></TR></TABLE>
No you purge into the open atmosphere. If you purge into your intercooler or turbo before a run your spraying your engine with alot of nitrous at idle.
Old Jul 25, 2006 | 08:38 AM
oh i thought it was purging the air from the lines... thanks though
BojeEM2
Honda Civic (2001 - 2005)
14
Sep 12, 2007 02:13 PM
BlackRocket
Oct 9, 2004 07:48 AM
Reddog
Dec 15, 2003 08:37 PM
integranator
Dec 22, 2002 02:58 PM
EFing8
Dec 19, 2002 07:59 PM
