Blow off valve not workin??new turbo install
today i installed my turbo kit in my 5th gen lude. well the BOV isnt workin. no idea why? I have the VAC source coming from the FPR hose. it should be fine..but nope. i did find a tiny leak in the mnifold at wich ill fix tomrrow. I dont think that it.
* I did take apart the BOV to make sure it was okay. I bouht it used.
any ideas????
any ideas????
Re: Blow off valve not workin??new turbo install (moops vs moors)
screw that. I paid $166 for this on a 2.5 pipe mounted.
i took it apart. is there something i put in backwards?
it has 3 nipples. the bottom 2 are looped, thats how it was when i got it. the top one goes by the TB. ontop to the right some. in the back. i moved it to the FPR vac line after i tries that spot.
i got it. i took it apart again. the valve was a bitch to move. so i used some wd40 an some greese. also fixed all the vac leaks...im good to go. thanks for the help.
