Start-up problem
Old Jul 22, 2006 | 08:36 AM
elpiar's Avatar
Default Start-up problem
My fueling and ignition setup is:
- RC 440cc injectors
- Stock fuel rail and regulator
- Crome tuned ECU (OBDI)
- SS blaster coil
During startup, this happens randomly. My idle kinda stutter, and the AF ratio is leaning out a bit (although I am set up for closed loop), if I drive into boost a little here and there, the problem stops, or if I tip in the throttle a bit, the problem also stops momentarily. Sometimes, initial drive, just cruising along the fuel is leaning out also.
Do you think my problem is in ignition or in fueling?
noluckracing
Engine Management and Tuning
Sep 14, 2009 04:38 PM
rohec04
Sep 29, 2005 05:57 PM
XES
Sep 21, 2002 12:47 PM
